Pros & Cons of F/I - Mustang Evolution
Old 05-11-2013, 10:12 AM   #1
theweekday's Avatar
Pros & Cons of F/I
Can someone enlighten me on the differences of regular superchargers and prochargers please
ID:	107316   Click image for larger version
theweekday is offline   Reply With Quote
Old 05-11-2013, 10:17 AM   #2
BigB227's Avatar
The left picture is a roots type supercharger which can be broken down into a twin screw supercharger, they are better for the low to mid torque ranges and make power almost instantly and constantly. The pro charger is a centrifugal type supercharger which is basically a turbo except it is run off the belt and not exhaust. It makes more power towards the high end range and is te easiest of the two for installation. The centrifugals do suffer a bit of lag but not near as bad as a turbo.
BigB227 is offline   Reply With Quote
Old 05-11-2013, 10:19 AM   #3
MidnightBlueGT's Avatar
Search bar is your friend.
http://m.mustangforums.com/forum/sho...d.php?t=582495
Old 05-11-2013, 10:23 AM   #4
theweekday's Avatar
Originally Posted by MidnightBlueGT View Post
On the phone it doesn't always show up
Old 05-11-2013, 11:02 AM   #5
Mile high JDF's Avatar
Twin Screws also suffer from heat soak issues. When you see a race between cars putting down the same numbers the centrifugal car almost always wins because they continue making power all the way through the power band.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-11-2013, 11:30 AM   #6
BigB227's Avatar
Also from what I understand centrifugals are more street friendly
Old 05-11-2013, 04:44 PM   #7
Depends on what you want. Roots/PD style=instant power. Centri has to spool up but will make more peak power. Then you have a turbo which is the most efficient, properly sized will be in full spool pretty quick and will not run out of power on the top end. Also does not rob power to make power.
Old 05-11-2013, 08:32 PM   #8
theweekday's Avatar
I got a real good deal on a vortech so I'm weighing my options
Old 05-11-2013, 09:46 PM   #9
Bolt the vortech on and go.
Old 05-12-2013, 04:01 PM   #10
Region: Arkansas
This.
I have a research paper on turbo/SC that includes a paragraph or two about Positive displacement and centrifugal superchargers if you're interested.
BackPressure is offline   Reply With Quote
Old 05-13-2013, 04:06 PM   #11
Also,
Auto= Go turbo
Stick= Go supercharger
Old 05-13-2013, 06:42 PM   #12
2002VertGT's Avatar
Originally Posted by BackPressure View Post
This.
I would love to read this paper..
4.10 Gear/RPM thread
Old 05-13-2013, 09:13 PM   #13
I will say that almost nothing in the world sounds better than a screaming M112 on a Cobra/Lightning. The KB/Whipples sound great too as do some of the other power adders but NOTHING sounds nearly as good as the Eaton stuff...
01:46 PM
