Mark 8 questions - Mustang Evolution
Old 05-11-2013, 08:01 PM   #1
mcvicar04's Avatar
Mark 8 questions
Hey guys came across a good deal on a mark 8 motor my question is that can I use that block and use 2v heads, connecting rods and pistons? I want to make my car sneaky quick and my other question is what's the quality of the crank like max hp? Thank guys
mcvicar04 is offline   Reply With Quote
Old 05-11-2013, 08:25 PM   #2
98vertgt's Avatar
If you get the mark 8 motor use the heads. Otherwise don't bother
98vertgt is offline   Reply With Quote
Old 05-11-2013, 08:59 PM   #3
mcvicar04's Avatar
Well I have 2 valve stuff I have the turbo manifolds and acc. I just want a really good bottom end
Old 05-11-2013, 09:59 PM   #4
The rods and pistons in the Mark VIII are no stronger than the ones in your 2V. The Mark VIII motors are good for ppl who want to convert to 4V on the cheap or want the Teksid block.
Old 05-11-2013, 11:19 PM   #5
98vertgt's Avatar
Look for a used 03/04 cobra block then. All others are almost the same in power capabilities.
Old 05-12-2013, 03:57 PM   #6
Region: Arkansas
Actually the block out of the MKVIII cannot even be compared to any other block. The MKVIII has a Teksid block, which is arguably the best block that Ford has produced. it's Italian designed and incredibly strong. The aluminator block is nothing compared to a Teksid.
BackPressure is offline   Reply With Quote
Old 05-12-2013, 04:12 PM   #7
mcvicar04's Avatar
thats why i want it, it can handle what ever i throw at it, and i dont wabnt to deal or pay for the 4v swap, ill port and polish my heads get a good crank connecting rods and pistons and build up my turbo. and a junk yard near me only charges 200$ for the entire motor
Old 05-12-2013, 04:30 PM   #8
98vertgt's Avatar
I know that. I'm talking about the internals.
Old 05-12-2013, 04:36 PM   #9
mcvicar04's Avatar
so the internals are also rated for high hp?
Old 05-12-2013, 05:16 PM   #10
98vertgt's Avatar
Not the internals. Just the block
Old 05-12-2013, 05:32 PM   #11
Rosco's Avatar
+1 on the teksid block. Use the 4v mark heads and get new headers? Better power potential.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 05-12-2013, 07:22 PM   #12
Mzilla's Avatar
I have a teksid block with Kellogg forged crank, eagle h beam rods, JE pistons, all ARP 2000 fasteners. I also added a set of Kaase ported polished heads. The teksid block is the most sought after light weight aluminum block out there. These blocks when properly assembled can handle 1000+ rwhp.
Mzilla is offline   Reply With Quote
Old 05-13-2013, 03:45 PM   #13
Yup, the Teksid is the best block Ford ever put in a Mustang, I'd go as far as to say even better than the Coyote blocks. They are super light, super strong and Teksid the the company that makes the Ferrari blocks. IMO, if Ford had not stopped with the Teksid blocks due to the high cost vs the WAP or cast iron, the 03/04 Terminators would for sure have been Teksids and honestly really do need that weight off the nose of the car...
Old 05-14-2013, 03:48 PM   #14
Region: Arkansas
Teksid + Manley 18cc pistons, Manley H beams (or billet I beams if you want an absolutely bullet-proof setup), Clevite bearings, and the rest Manley will handle anything you can imagine.
Old 05-14-2013, 03:55 PM   #15
mcvicar04's Avatar
Yea I am goin to ocmd this weekend and when I get back the build starts
11:06 PM
