need help with this knock - Mustang Evolution
Old 05-12-2013, 04:07 PM   #1
goody's Avatar
goody is offline   Reply With Quote
Old 05-12-2013, 04:31 PM   #2
67mustang97's Avatar
Region: Vermont
I tried to help but your video is private.
Old 05-12-2013, 04:45 PM   #3
goody's Avatar
That was a my bad the videos unlocked now
Old 05-12-2013, 04:56 PM   #4
Region: Vermont
Doesn't sound good sounds like maybe bad bearings. Does it smoke or have any exhaust leaks under the hood? What's your oil look like is it full does it look normal or milky?
Old 05-12-2013, 04:59 PM   #5
goody's Avatar
It smokes a little bit behind the left valve cover and oils clean but antifreeze started getting milky and like snot
Old 05-12-2013, 05:50 PM   #6
98vertgt's Avatar
I say a bent rod
98vertgt is offline   Reply With Quote
Old 05-12-2013, 06:04 PM   #7
Tomb1987's Avatar
Does it over heat
2002 mustang gt
Future beast
Tomb1987 is offline   Reply With Quote
Old 05-12-2013, 06:09 PM   #8
goody's Avatar
Yeah I've flushed out the cooling system a few times but it doesn't last too long before it starts again
Old 05-12-2013, 06:15 PM   #9
schmitty426's Avatar
sounds like a bad valve lifter i had that same knock in an old stang i owned or a bent rod its only a matter of time before it goes sorry, but its the truth :/
schmitty426 is offline   Reply With Quote
Old 05-12-2013, 06:16 PM   #10
Tomb1987's Avatar
Maybe badly blown head gasket. U can take it to some shops and they can tell you whether or not ur getting exhaust in your coolant.
2002 mustang gt
Future beast
Old 05-12-2013, 06:19 PM   #11
goody's Avatar
Well I planned on with getting an engine for it so any ideas what would be best I'm looking to up the size
Old 05-12-2013, 06:32 PM   #12
Tomb1987's Avatar
I just ordered a 5.0 stroker longblock from jdm engineering in freehold nj
2002 mustang gt
Future beast
Old 05-12-2013, 06:39 PM   #13
goody's Avatar
I'm still looking around I wanna try to stay true to it 4.6 line but if all else fails gonna upgrade
Old 05-12-2013, 06:44 PM   #14
1lowGT's Avatar
Rod knocking
---------- Post added at 07:44 PM ---------- Previous post was at 07:43 PM ----------
But then again I agree with the gasket.
Old 05-12-2013, 06:51 PM   #15
98vertgt's Avatar
Try and drop a whole pi engine in it. Shouldn't be too expensive
Old 05-12-2013, 06:52 PM   #16
ksrumbel's Avatar
Either a rod knock or a spun bearing. Motor is toast.
ksrumbel is offline   Reply With Quote
Old 05-12-2013, 07:34 PM   #17
Ubnbit's Avatar
Dang man, I hate that. How mechanical are u? If u tore it down u could find it.
Old 05-12-2013, 08:14 PM   #18
blackbeast12's Avatar
Region: Delaware
Engine is toast , good reason to do a coyote swap!!! Get r done!!!
2016 Gt/Cs autowith 3:55', mbrp cat back and a n/a build on the way!...
blackbeast12 is offline   Reply With Quote
Old 05-13-2013, 06:34 AM   #19
goody's Avatar
If I switch to a coyote what will I need to swap as well
Old 05-13-2013, 07:31 AM   #20
Region: Delaware
Here you go:
Engine Swap Guide - Heavy Rotation - 5.0 Mustang & Super Fords Magazine
Old 05-13-2013, 09:44 AM   #21
goody's Avatar
Badass appreciate it
Old 05-13-2013, 08:45 PM   #22
jjsg09's Avatar
Sounds like if you've been having overheating issues you blew a head gasket plus you said your coolant is milky that's a dead giveaway. But also sounds like a spun rod bearing.
» Members Mustangs
My car
Boostr
5.0
mrblacknut
Add your Mustang
11:38 AM
