New engine needs tune - Mustang Evolution
Old 05-12-2013, 05:20 PM   #1
67mustang97's Avatar
Region: Vermont
I fired up my new engine it's a 5.1 stroker with Trick Flow twisted wedge heads and 270 Comp Cams. My question is the car was tuned with these cams but in a stock head and block engine. The car currently starts harder than it did before and the engine shakes during idle is this normal without a fresh tune? The shop that did the cam install supposedly degreed the cams but when I look at the timing marks they appear to be set as the factory would. I figured degreeing cams would have the timing marks moved a little but maybe I'm wrong? Does anyone know of a reputable shop in the New England area that could check the cams? I'm willing to travel a few hundred miles if I have to. Thanks
Old 05-12-2013, 09:05 PM   #2
blackbeast12's Avatar
Region: Delaware
Yes sir, have it dyno tuned if you have the bux...
2016 Gt/Cs autowith 3:55', mbrp cat back and a n/a build on the way!...
blackbeast12 is offline   Reply With Quote
Old 05-12-2013, 09:37 PM   #3
MidnightBlueGT's Avatar
Give her a tune
---------- Post added at 10:37 PM ---------- Previous post was at 10:36 PM ----------
Thatll make the timing correct
12:23 PM
