throttle body help - Mustang Evolution
Old 05-13-2013, 02:07 PM   #1
schmitty426's Avatar
throttle body help
I just installed my mac 70mm throttle body and went to start it and the rpms are high to about 1200k is there a way to fix this?
schmitty426 is offline   Reply With Quote
Old 05-13-2013, 02:12 PM   #2
Also when gas is lightly touched rpms stay that high and take about 15 seconds to calm back to idle
Old 05-13-2013, 03:16 PM   #3
I recently cleaned my TB and had similar symptoms. The idle went back to normal after driving for a bit. Computer needed to figure it out I guess. You might try disconnecting the battery for a while and let the computer reset and start fresh with your new set-up.
Old 05-13-2013, 03:26 PM   #4
Ok so I put the stock throttle body back on and now it idles and revs just fine I think the throttle cables too tight for the throttle body is there any way to adjust it
Old 05-13-2013, 03:32 PM   #5
I don't think so. Was the throttle plate all the way closed on the Mac?
Old 05-13-2013, 03:34 PM   #6
Yeah and when i pressed the gas ever so lightly it woulgo to about 2300 and stay there for 15 seconds and go back down
Old 05-13-2013, 03:40 PM   #7
goodwinta1's Avatar
Schmitty, can you sit the new TB on top of the stock one and take a good picture of the setup?
goodwinta1 is offline   Reply With Quote
Old 05-13-2013, 03:42 PM   #8
Disconnect the battery. Put the Mac back on. Then reconnect the battery. It sounds like the computer needs to reconfigure. Make sure the throttle plate closes all the way once it's installed.
Old 05-13-2013, 04:02 PM   #9
I dont have a camera atm I dropped a socket wrench on the lens today otherwise I would lol
Old 05-13-2013, 04:03 PM   #10
1lowGT's Avatar
Make sure the throttle cable isn't messed up
Old 05-13-2013, 04:05 PM   #11
I did everything u stated and let it run a few minutes and still touch the gas a bit and it stays up for a about 3 seconds now and drops back to idle
Old 05-13-2013, 04:08 PM   #12
Awesome! Drive it for a while and it should be fine.
Old 05-13-2013, 04:10 PM   #13
goodwinta1's Avatar
Is the setup the same on both? Is the throttle resting on the mechanical stop when at idle?
Old 05-13-2013, 04:20 PM   #14
No its resting just b4 the stop but the plate is fully closed and the plate is what's stopping it
---------- Post added at 05:20 PM ---------- Previous post was at 05:19 PM ----------
Drove it for a bit and still the same thing it won't idle unless I'm stoped for 3-5 seconds
Old 05-13-2013, 04:27 PM   #15
Ubnbit's Avatar
Have u tried driving it yet?[COLOR="Silver"]
there has to be an adjustment on it somewhere.
---------- Post added at 06:27 PM ---------- Previous post was at 06:25 PM ----------
I wish I could see it.
Old 05-13-2013, 04:35 PM   #16
Ubnbit's Avatar
The butterfly should stay open a little at idle.
There should be a set screw on it to adjust it down.
Old 05-13-2013, 04:40 PM   #17
White03GT's Avatar
When changing your tb and plenum it's best to start it and just leave it running until the temp gets up. Took mine about 20-25 min and I had no problem
White03GT is offline   Reply With Quote
Old 05-13-2013, 04:42 PM   #18
Lol. It may take more than 5 min Schmitty. Yea some pics would be helpful. Im concerned about the throttle plate being the stop. If there is an adjustment screw I would set it so that the throttle closes on that with the plate still being all the way closed. Am I making any sense?
Old 05-13-2013, 04:45 PM   #19
Ubnbit's Avatar
+1. Let it do its thing bro. Then after warm, drive for about 20 minutes.
Old 05-13-2013, 04:54 PM   #20
Well the cops just rolled up and said I need to quit cus of the high idle and slp lm1's and an x pipe Arnt neighborhood friendly lol
---------- Post added at 05:54 PM ---------- Previous post was at 05:53 PM ----------
Ill try again tomorrow after work and try everyones method thank u all I really appreciate the help I will follow up tomorrow
Old 05-13-2013, 04:55 PM   #21
Ubnbit's Avatar
Then drive it down the road where there is Nobody around and let it do its business lol.
Old 05-13-2013, 05:21 PM   #22
1lowGT's Avatar
F******* cops what the hell. Too bad they dont know your exhaust is illegal lol
Old 05-13-2013, 05:33 PM   #23
Lol no emissions in mn
Old 05-13-2013, 06:55 PM   #24
AgentOrange's Avatar
There should be a stop for the plate somewhere you can adjust, its just a basic screw, makes contact with the arm you hook your throttle cable into. Also your TPS may have decided it's not your friend anymore.
AgentOrange is offline   Reply With Quote
Old 05-13-2013, 07:10 PM   #25
Just bought a new tps today
Old 05-14-2013, 11:00 AM   #26
Ewokjax95's Avatar
Not sure why no ones said it yet, but more than likely is tps. When switching throttle bodies, especially to an aftermarket tb, the tps has adjustments that need to be set. The symptoms you're describing are what happens when the voltage is wrong.
Ewokjax95 is offline   Reply With Quote
Old 05-14-2013, 11:11 AM   #27
I did. A lot of the time they never work right again after removing them too. Especially the guys that beat the crud out of the screws with an impact driver. He did say he bought a brand new tps though.
Old 05-14-2013, 12:44 PM   #28
I think nobody mentioned it because he put it back together with the old set up and it ran fine. My TPS does not look like its adjustable.
Old 05-14-2013, 12:49 PM   #29
Idle set screw.
Old 05-14-2013, 12:52 PM   #30
Originally Posted by AgentOrange View Post
Idle set screw.
Huh?
Old 05-14-2013, 01:10 PM   #31
Huh?
If he swapped the TB, had those symptoms, and the old TB/TPS works, then the idle set screw isn't set right.
Old 05-14-2013, 01:20 PM   #32
Ok. I figured out what you're saying AO. That TB should have been adjusted fairly close from the factory. The computer will normally make the needed correction. It sounds though, from Schmittys earlier posts, that the set screw is not adjusted properly. Whether he did that trying to get the idle down or it came that way, I dont know. But you may be on to something AO. You should never have to mess with that screw normally. That's what the IAC is for.
Old 05-14-2013, 02:19 PM   #33
True with factory TBs, aftermarkets usually require adjustment (the BBK throttle intake and Trick flow TB I have used did). I had similar idle issues with my 04 before I set mine..
Old 05-14-2013, 02:39 PM   #34
I never touched the idle screw I even lowered it lol right now the butterfly is what's stopping now I have the screw slightly touching the throttle tounge and its idleing at about 1000... Do I have to do anything with the butterfly screws?
Old 05-14-2013, 02:48 PM   #35
No. Don't touch the butterfly. Adjust the screw until you see it move the throttle plate just a hair, and give it a shot. Make further adjustments from there.
12:34 PM
