o/r x install..stripped bolt - Mustang Evolution
Old 05-13-2013, 07:29 PM   #1
v8pony's Avatar
Whatsup guys, got a problem here..went to install my upr o/r x, hit all the bolts with PBblaster, broke them all free but the final passenger side manifold bolt, the bottom one that requires the swivel and all..well I stripped the bolt and got completely stuck..tightened everything back up and went on with my day...any easy way to remove that stripped bolt?
2002 5spd GT
Feb 2013 Mustang of the Month
Old 05-13-2013, 07:49 PM   #2
ksrumbel's Avatar
Matco Tools sells a bolt extractor socket set. It is awesome and you won't have to worry about rounding off bolts. Get it.
ksrumbel is offline   Reply With Quote
Old 05-13-2013, 10:13 PM   #3
v8pony's Avatar
very expensive..i was thinking about giving the irwin deeep socket extractor set for like 15-25$ a try, any experience with them? also if the extractors dont work, what are my options? i hate to see the x pipe sitting
2002 5spd GT
Old 05-13-2013, 10:42 PM   #4
tc x 4's Avatar
Craftsman sells a cheap set.
Old 05-13-2013, 11:08 PM   #5
I'm surprised i didn't mangle any of my bolts when i swapped my midpipe, even with 140k they still came out fine (they were a PITA, but came out fine)
Old 05-14-2013, 07:10 AM   #6
v8pony's Avatar
How is that set? I've heard good and bad things about it, I also hear you pretty much got 1 shot with an extractor, you mess it up your pretty much screwed..I do not want to bring it to a shop unless I HAVE to, come inspection I have to swap back to stock H, so I'd love to do it in the comfort of my driveway so I can throw the stock H in my garage and should be push and pull come September inspection time
---------- Post added at 09:10 AM ---------- Previous post was at 09:09 AM ----------
Luck! None of mine were bad at all except the final passenger side bottoms manifold bolt, it's not 100% rounded because I stopped after I knew I stripped it. So hopefully an extractor will work, but I need a deep socket 3/8 15mm deep socket, pretty sure from what I saw of the craftsmans set that there not deep sockets, Has to be deep to get over the stud
2002 5spd GT
Old 05-14-2013, 09:15 AM   #7
1lowGT's Avatar
Craftsmen is very good tools.
02:37 AM
