ROMEO OR WINDSOR - Mustang Evolution
Old 05-14-2013, 09:07 AM   #1
Allans03ragtop's Avatar
ROMEO OR WINDSOR
How can you tell which 4.6 motor you have?
The windsor or the romeo.
03 Sonic Blue CONVERTIBLE W/STYLE BAR AND SPEEDSTER COVER AND 18X10W/275/35 REAR AND 18X9W/245/45 FRONT. OFF ROAD X-PIPE 40 SIERIES FLOMASTERS AND CAI.
Allans03ragtop is offline   Reply With Quote
Old 05-14-2013, 10:07 AM   #2
98vertgt's Avatar
I believe it's 99+ it's a Romeo.
98vertgt is offline   Reply With Quote
Old 05-14-2013, 12:59 PM   #3
Mustang936's Avatar
Windsors were 99 to mid 01 and then they switched to the Romeo engines.
VIN Decoder - The Mustang Source - Ford Mustang Forums
Theres a link to a VIN decoder
Edit: A vin decoder wont tell you which enigne you have(Thanks Cliffy for clarification) but ill leave it hear because its cool to see what you vin tells you about your car.
Mustang936 is offline   Reply With Quote
Old 05-14-2013, 01:38 PM   #4
cliffyk's Avatar
There is nothing in the VIN that will determine Romeo or Windsor--all GTs have an X in position 8, just indicating it is a 4.6L SOHC engine. I am on a mobile tablet right now, however I will post the Ford VIN decoder info later that shows this.
A lot of Mustang sites have this wrong, it's like the confusion over EV1 vs EV6 injectors...
Old 05-15-2013, 05:53 AM   #5
WheelStander's Avatar
Which one has an 8 bolt fly from factory?
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 05-15-2013, 07:47 AM   #6
cliffyk's Avatar
All Romeo 4.6 engines have 6-bolt cranks; the Windsors came in 6 and 8 depending on application--all Mustang Windsor engines are 8-bolt.
Re the VIN engine code: this (below) is from the 2000 MY VIN decoder on Ford's online VIN tools site:
You can see the X engine code indicating a 4.6L SOHC Mustang engine made in Windsor (the W in the engine/liter column). The W VIN engine code is for the engines used in other Ford products, still made at the Romeo plant in 2000...
Old 05-15-2013, 07:55 AM   #7
theweekday's Avatar
Can someone tell me the difference between the two? (Romeo & windsor)
theweekday is offline   Reply With Quote
Old 05-15-2013, 08:02 AM   #8
Thanks CliffyK, I have the Windsor then.
---------- Post added at 10:02 AM ---------- Previous post was at 09:57 AM ----------
Rebuilding the Ford 4.6L SOHC Engine: Engine Builder
Old 05-15-2013, 08:08 AM   #9
cliffyk's Avatar
Functionally, not a thing.
Mechanically there are a number of differences, too many to get into here; just Google "Romeo vs Windsor" and start reading (ignoring the W vs X VIN myth of course).
This is a good article from Engine Builder magazine...
08:36 AM
