pi swap problems... - Mustang Evolution
Old 05-14-2013, 04:16 PM   #1
98GTCONV's Avatar
pi swap problems...
So just completed the swap, now im having power issues and knocking noises in the top end. One noise may be a bad lifter, the other sounds like the timing chain isn't tight enough. Very loud noise like its hitting the cover. When I drive it cold, it runs great but once it starts to heat up, noises get louder and it runs like crap, bogging, choppy throttle. I got it back in the garage and plan on breaking it down once again...
98GTCONV is offline   Reply With Quote
Old 05-14-2013, 07:54 PM   #2
1996mustang's Avatar
Take a video of the noise. Did you change the tensioners ob both sides? If you didnt thats a possible reason for that chain and would also be bad if you bent any valves when it jumps timing
Old 05-14-2013, 09:20 PM   #3
98GTCONV's Avatar
I bought new chains, tensioners, and guides.
09:25 AM
