Bullitt won't start - Mustang Evolution
Old 05-14-2013, 10:12 PM   #1
Bullitt won't start
Ok so as i was leaving today i got in the car and went to turn it on but when i did it just clicked and then nothing, and the power short circuited and didn't come on for about 2 minutes. I had to go to a meeting so i took a different car to that.
When i got back it was dark out so when i tried it again i would turn the key to the on position and it would cut all the power (so the dome light and the entire dash would shut off). When the power is off i will hear a clicking sound coming from the steering column. Through all this the theft light will still be flashing.
Also when i press the lock button on the key fob it locked a few times and other times it didn't, same with the unlock. But when i pressed the lock 2 times for the alarm it would lock and then half the time it wouldn't honk the horn for the alarm. I could hear a little sound coming from the horn area (wasn't a honk, was some other sound).
I think its some sort of relay or maybe a bad battery terminal. What do all of you think?
Old 05-14-2013, 10:19 PM   #2
2300turboford's Avatar
Man I have no idea but on a side note I'm getting my black bullitt Sunday check out my thread in special edition mustangs
Old 05-14-2013, 10:22 PM   #3
Yea i saw that thread.
Old 05-14-2013, 10:23 PM   #4
Was a lot cleaner than I expected it just needs some tlc I can't wait to get it
Old 05-14-2013, 10:39 PM   #5
Venomouz831's Avatar
Check and make sure you're battery cables are tighten. I had the exact same problem and turned out one was loose and I had to tighten it
)02 Gt, Founder of WE2G
Old 05-14-2013, 10:41 PM   #6
It could be as simple as a bad battery in the key fob. Is your car key chipped, do you know? Sometimes if the battery is dead in the fob it will trigger the anti theft system.
Good luck bro!!!!
---------- Post added at 12:41 AM ---------- Previous post was at 12:40 AM ----------
+1
Old 05-14-2013, 10:49 PM   #7
Like Venom said, check the cables. Try jump starting it. If it starts , my vote goes for a bad battery. Good luck!
Old 05-14-2013, 10:49 PM   #8
yea the key is chipped. I can try my other key fob and key tomorrow and see what happens.
---------- Post added at 09:49 PM ---------- Previous post was at 09:49 PM ----------
i'll do that with the terminals tomorrow, thats also what DavidSeifert said to do.
Old 05-14-2013, 11:34 PM   #9
Tyoung68's Avatar
Sounds like a bad ground to me had the same sort of problem with my car
Old 05-14-2013, 11:50 PM   #10
All this is starting to make me feel better
Old 05-15-2013, 12:06 AM   #11
Tyoung68's Avatar
If its the cables get some baking soda and water and a wire brush mix the baking soda and water together as it will neutralize the battery acid an scrub the terminals and and cable it self the sell battery cable / wire terminal brushes they cant be more what 5 bucks
Old 05-15-2013, 12:12 AM   #12
Slow4V's Avatar
Dead battery
Old 05-15-2013, 01:44 AM   #13
98vertgt's Avatar
Dead battery or dead cell in the battery
98vertgt is offline   Reply With Quote
Old 05-15-2013, 07:57 PM   #14
Jgill1992's Avatar
Yea I'm thinking battery issue my old 91 f150 had a lot of weird electrical issues because one of the battery cables was corroded
2015 Mustang GT Premium. No mods yet.
Jgill1992 is offline   Reply With Quote
Old 05-15-2013, 08:35 PM   #15
Oh I forgot to post, but she's running again. Disconnected the battery terminals for about 5 minutes, reconnected them and it fired right up.
Old 05-15-2013, 09:57 PM   #16
Good
Old 05-16-2013, 08:18 AM   #17
Ckennedy121's Avatar
Not sure if the terminals were loose or just poor qualities but I went out and bought new "heavy duty" terminals because my old ones were...just that old and beat up and oxidizing from the battery acid.
Anyway it's an easy $7 and an easier 10-20 minute job but then you don't have to worry about it anymore.
Ckennedy121 is offline   Reply With Quote
Old 05-16-2013, 09:25 AM   #18
Yea I might do that
Old 05-16-2013, 09:51 AM   #19
Cornkush's Avatar
Lol...
Cornkush is offline   Reply With Quote
10:56 AM
