Injectors - Mustang Evolution
Old 05-15-2013, 09:57 PM   #1
Mustang_Madness's Avatar
Injectors
Can i use the 24# black injectors on my 98 engine
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 05-15-2013, 10:04 PM   #2
Region: Arkansas
Are you wanting to up the power later on down the road? If not, there's really no reason to increase injector size.
BackPressure is offline   Reply With Quote
Old 05-15-2013, 10:06 PM   #3
1lowGT's Avatar
+1 no need unless you go FI later.
Old 05-16-2013, 06:36 AM   #4
cliffyk's Avatar
You can.
It will require a new tune to run properly, and then make absolutely no difference in engine output...
Old 05-16-2013, 08:03 AM   #5
Mustang2004Gt's Avatar
Does anyone know if the 2004 GT came with 19# injectors or the 21# injectors because I have been hearing both
Mustang2004Gt is offline   Reply With Quote
Old 05-16-2013, 08:06 AM   #6
Horseplay's Avatar
im pretty sure urs has the 21 becuase ford upgraded them from the 19 after 2003 or something. or 2002 not sure. but yeah u got the 21
Low2v
Old 05-16-2013, 08:07 AM   #7
But they didn't change the tune on the computer correct?
Old 05-16-2013, 08:09 AM   #8
Horseplay's Avatar
that i dont know. im pretty sure they changed
something on the computer since they made that change
Low2v
Old 05-16-2013, 08:10 AM   #9
I've been hearing that after they changed it they didn't change the ecu so the car runs extremely rich and injectors are only running at like 80%
Old 05-16-2013, 08:11 AM   #10
Horseplay's Avatar
hmm. well buy a tuner and that will fix the issue if thats the case
Low2v
Old 05-16-2013, 08:12 AM   #11
That will be my next purchase. Do you suggest a bama tune or going to a dyno?
Old 05-16-2013, 08:18 AM   #12
Horseplay's Avatar
ive never been on a dyno. but cant go wrong with either. i just bought an sct handheld and got my custom tunes from someone i was referred to that has a performance shop .
Low2v
Old 05-16-2013, 08:25 AM   #13
Ill probably just end up going with bama again.
Old 05-16-2013, 08:40 AM   #14
cliffyk's Avatar
The very late 2002s and all 2003 and 2004 GTs had the pink (lavender) 21 lb/h injectors, there were no changes to the tune that I have every observed (I have worked with 55 to 60 '00 to '04 GT tunes).
With both the 19 lb/h (orange) and 21 lb/h injectors the significant values, low and high injector slope, in the tunes are the same--23.8 and 19.2 lb/h.
The tunes for engines having the 21 lb/h injectors can be greatly improved by changing these to 24.1 and 20.5 lb/h. The slight change in the low slope makes the cranking AFR a bit richer to help hot starting after a brief heat soak; the 1.3 lb/h change in the high slope leans out the open-loop mix...
Old 05-16-2013, 10:41 AM   #15
Damn guys. Yall know alot about these. Especially Cliffy.
Now, i heard that throughout the years of 96-04, the injectors changed colors but kept the same #s. why is that? I have 2 sets of 19# injectors and want 21 or 24# because im in the process of a pi swap,LT headers,75mm tb, and a tune after. Just need to know the right color/#s for all of that.
Old 05-16-2013, 11:21 AM   #16
1lowGT's Avatar
I'm not sure when they switched over to 21# pink tops. Cliffy will step in and make me sound stupid soon lol.
Old 05-16-2013, 05:05 PM   #17
Region: Arkansas
They switched late in 2002 because the 19# injectors were close to being maxed out at high loads.
Old 05-16-2013, 06:38 PM   #18
cliffyk's Avatar
Mostly because those that say that don't know what they are talking about...
11:01 AM
