Creaking sound - Mustang Evolution
Old 05-16-2013, 05:07 PM   #1
JayStang718's Avatar
Creaking sound
Every time I brake I hear a creaking sound coming from the front of the car. Even if I break a little it still creaks. Another issue im having is when I turn the steering wheel I hear a creaking sound. Can some one please help I was thinking maybe a ball joint but I'm not sure.
JayStang718 is offline   Reply With Quote
Old 05-16-2013, 05:59 PM   #2
MidnightBlueGT's Avatar
Have you checked the pads or bearings?
Old 05-16-2013, 06:03 PM   #3
No I haven't checked either I didn't no that pads would make a creaking sound and when u say bearings your referring to the wheel bearings right?
Old 05-16-2013, 06:07 PM   #4
I mean a squeal yes for pads. And yeah, my cousins car had a creaking problem when he stopped and turned and he said it was a problem with the bearings.
Old 05-16-2013, 06:11 PM   #5
Ohh ok the turning creak has been happening for about 2 months now but it was very light but as I was driving today it got annoying loud and it started to creak also when I started to break. I'll check the bearings thanks for the help
Old 05-16-2013, 07:27 PM   #6
cliffyk's Avatar
Might be this...
Old 05-16-2013, 07:43 PM   #7
Originally Posted by cliffyk View Post
It might be what I'm going to do I have a shop in my school I'm going to bring my car in and put it on the lift and listen for the sound then
Old 05-16-2013, 07:49 PM   #8
Mine's starting to do it too. I've been suspicious of the rack. Gonna have a look. Thanks Clffy!
Old 05-18-2013, 03:27 PM   #9
1996mustang's Avatar
Could be comtrol arm bushing or ball joints. Those have a creeking sound as well while turning or braking. I would check those
02:15 PM
