01 mustang GT cluster gauge - Mustang Evolution
Old 05-17-2013, 03:47 PM   #1
Xaperez100's Avatar
Lights won't come on not do the brake lights unless you press the brake or turn but they won't turn on when you pull the Light switch out. Headlights come on though.
Xaperez100 is offline   Reply With Quote
Old 05-17-2013, 04:03 PM   #2
Count Dragula's Avatar
Fuse I believe
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 05-17-2013, 04:26 PM   #3
Xaperez100's Avatar
Originally Posted by DSG2003 View Post
Fuse I believe
All fuses seem to be in tact.. None are blown
Old 05-17-2013, 04:26 PM   #4
Venomouz831's Avatar
You checked them with a fuse tester?
)02 Gt, Founder of WE2G
Old 05-17-2013, 04:35 PM   #5
Just put in a new fuse.
straybullitt is online now   Reply With Quote
Old 05-17-2013, 04:56 PM   #6
Xaperez100's Avatar
I've put in new fuses.. The cluster works. But the lights for the gauges don't turn on or the take lights. But the other lights come on like the miles and the CEL and brake and all those little ones show.
Old 05-17-2013, 04:59 PM   #7
Have you tried replacing the wiring? I think late model restoration has one
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 05-17-2013, 05:14 PM   #8
Ok. I might have been wrong about the instrument lights and tailights being on the same circuit. All I have to go by at the moment is the owners manual I dont even see tailights mentioned. Only brake lights.
Old 05-17-2013, 05:29 PM   #9
He isn't talking about tail lights or brake lights I don't think. I think he is talking about the instrument panel. I may be wrong but I think he is talking about the cluster and the lights at the bottom of it.
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 05-17-2013, 05:32 PM   #10
Hmmm. Now Im curious. I'd hate to be in a parking lot at night, trying to use the owners manual to troubleshoot a relatively minor problem. Am I missing something? Which fuse location is for the tailights?
Old 05-17-2013, 05:53 PM   #11
I think that its the tailights and instrument lights. Do you have your owners manual handy DSG?
Old 05-17-2013, 06:08 PM   #12
Alright. I found it. The fuse is in the power distribution box. Under the hood. Location #10. 30 amp fuse. Probably for the instruments too. I learn something every day!
Old 05-19-2013, 10:44 PM   #13
Xaperez100's Avatar
Headlights on and still nothing cluster gauge lights don't turn on only the warnings and mileage
Taillights don't come on either...
Old 05-19-2013, 10:53 PM   #14
Did you check the fuse in the power distribution box under the hood.
Old 05-19-2013, 10:56 PM   #15
deadsp0t's Avatar
It's either the headlight switch itself or the harness that plugs into it.
Remove the knob on the switch and the two screws that hold the trim around the gauges on and remove the trim.
Two screws hold the switch in place, pull the switch and inspect the harness.
Make sure all the female pins are pushed down and fit snugly over the male pins on the headlight switch.
Expect the harness/plug to be melted/charred. They can be brittle so be careful.. If its melted beyond use, you can probably get on at a junk yard, or I believe AM sells a replacement.
This is a very common issue.
That's unimpressive
Old 05-19-2013, 11:02 PM   #16
Lol. Same problem on my F250. Been through about 5. Same thing on these too huh?
Old 05-19-2013, 11:04 PM   #17
Xaperez100's Avatar
Yup:/
---------- Post added at 12:04 AM ---------- Previous post was at 12:03 AM ----------
Wait same problem? What did you change out?
Old 05-19-2013, 11:05 PM   #18
Check the headlight switch like Deadspot said.
Old 05-19-2013, 11:06 PM   #19
Xaperez100's Avatar
I did I'm gonna try something though ill tell y'all if it works out!
Old 05-19-2013, 11:07 PM   #20
deadsp0t's Avatar
100% it's the switch it harness/plug for the switch.. Had this issue on two mustangs and two thunderbirds
That's unimpressive
Old 05-19-2013, 11:28 PM   #21
---------- Post added at 12:28 AM ---------- Previous post was at 12:27 AM ----------
It was the 30 amp fuse and replaced it and now it works man and thank you so much
deadphantom is offline   Reply With Quote
Old 05-19-2013, 11:44 PM   #22
deadsp0t's Avatar
Really......
That's unimpressive
Old 05-19-2013, 11:45 PM   #23
Really......
Yes sir
Old 05-19-2013, 11:46 PM   #24
Handle change Perez? Glad I could help. If it blows again carefully inspect the headlight switch like Deadspot said.
Old 05-20-2013, 12:00 AM   #25
deadsp0t's Avatar
Exactly, fuses are a fail safe for something shorting out..
Check the headlight switch/plug, it's very likely damaged and will short and pop the fuse again or damage the switch.
That's unimpressive
Old 05-20-2013, 12:02 AM   #26
Xaperez100's Avatar
Yeah we got it there was a slit in the wire for some reason. We got it fixed though! Thanks for the help everyone!
Old 05-20-2013, 12:06 AM   #27
deadsp0t's Avatar
Glad you got it!
Electrical issue can be frustrating lol
That's unimpressive
Old 05-20-2013, 12:33 AM   #28
Xaperez100's Avatar
Glad you got it!
Yeah I know lol I'm usually good when it comes to electrical problems.. But when it happens I was puzzled lol I did notice any blown fuses lol
10:40 AM
