Sct tuner - Mustang Evolution
Old 05-17-2013, 05:07 PM   #1
96smoke's Avatar
Sct tuner
I already talked to the bama team at AM and I'm getting some new tunes sent to me but wanted you guys opinions/input
Put on a 87 street tune on my 96 GT. Upper intake plenum, K&N cai, o/r x pipe, slp lm1s. Stock for the most part but now when I'm cruising and the RPMS are at like 2200 I let completely off the gas and it doesn't drop like it used to... It goes down really slow now and I had the issue before when I had a vacuum leak but that's not the case now cause right when I put the tune on it does this
Anyone had this issue too?
96smoke is offline   Reply With Quote
Old 05-17-2013, 05:10 PM   #2
Count Dragula's Avatar
Are you talking about when it is still in gear or when you press the clutch in?
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 05-17-2013, 06:14 PM   #3
96smoke's Avatar
Well if I'm cruising in 3rd at 2200 and let off the gas not touching the clutch they go down really slow. If Im coming to a stop light and throw it in neutral, it's fine
Does the same thing at idle, rev up to 2200 or so and they drop really slow then it stops around 1200 and then drops down to 700 or so for the normal idle setting for the tune
Never did this before so I know it's the tuner and I'm sure they marked something up on my custom tune that I didn't have on the car like a MAF or TB
Old 05-17-2013, 06:43 PM   #4
1lowGT's Avatar
Did you submit that you had upgraded tb or maf if you do?
---------- Post added at 07:43 PM ---------- Previous post was at 07:43 PM ----------
Never mind i read the post over again.
Old 05-17-2013, 06:45 PM   #5
96smoke's Avatar
Lol they're sending me new tunes. Hopefully they work and fix it I just wanted to see if anyone else had the issue
Old 05-17-2013, 06:52 PM   #6
1lowGT's Avatar
I'm getting my tuner in tomorrow! Definitely stoked.
Old 05-17-2013, 07:01 PM   #7
96smoke's Avatar
Outside of this minor mishap, it's so worth it.. The amount of power gained is great and you can't help but smile from ear to ear
Old 05-17-2013, 08:47 PM   #8
1lowGT's Avatar
I can't wait!
Old 05-18-2013, 12:33 PM   #9
cliffyk's Avatar
There are a number of settings in the tune that control the virtual "dashpot" function the PCM uses to control rpm when the throttle is closed, both at idle and when it is closed when decelerating. They are generally not altered in performance tunes, not to say they cannot be...
Old 05-18-2013, 02:30 PM   #10
96smoke's Avatar
Just took the tune off and returned it to stock... Perfectly fine doesn't do it anymore so I know for sure it's something set in the tune
Old 05-21-2013, 01:35 PM   #11
96smoke's Avatar
Ok so since I posted this I've had 2 new sets of tunes sent to me and not one of them changed anything. The fact the RPMS don't hang during the stock ecu settings keeps me from believing that a part is malfunctioning because once the tunes on, it hangs RPMS.
I need some insight other than from the bama team cause nothing they've done has truly helped. I just don't know what it could be
Old 05-21-2013, 02:44 PM   #12
cliffyk's Avatar
Without knowing what changes BAMA made to the tunes it is not possible to say for certain why what you are experiencing is happening--though it does obviously seem to be the tune.
Unfortunately SCT, like all tuning product vendors, encrypt the tune files meaning they can only be viewed/edited with SCT software. With that access it would take just a few minutes to load the tunes side-by-side in an editor and see what the differences are.
What response/feedback have BAMA provided? Did they tell you what in the tune they have been "playing with" in attempting to fix the problem,
Old 05-21-2013, 03:15 PM   #13
96smoke's Avatar
Apparently in the most recent one they sent they messed with the dashpod and the TB opening etc. can't remember exactly what he said but I do remember he said the dashpod was the main things they messed with
Old 05-21-2013, 04:55 PM   #14
cliffyk's Avatar
They should just leave the dashpot settings alone and not change them from the stock tune.
Do you know what your box code (Ford calls it the catchword) is? It will be a 4-character code, three letters and a number, on a label on the PCM connector socket...
Old 05-22-2013, 06:44 AM   #15
96smoke's Avatar
Yeah it's GGL3
Old 05-30-2013, 05:13 PM   #16
96smoke's Avatar
Bringing this back..
So took some carb cleaner and checked everywhere to see if I had a vacuum leak. And it didn't have one but when spraying between the stock TB and my aftermarket plenum, it changed the idle. So I'm thinking get a 70mm TB, or it needs a new gasket?
Also, with my tune on it's making the alternator whine loudly as if I had a s/c lol and it seems as if it's running harder...
And during all of this it's still throwing p1443, so could the TB/plenum issue be causing it? Ik it's for the purge valve but I'm really confused now lol
Thanks for the help
Old 05-30-2013, 06:51 PM   #17
cliffyk's Avatar
That is a vacuum leak.
Or just a new gasket.
Thanks for the help
I cannot imagine what settings in the tune could cause the generator to whine, unless the idle speed is too high...
Old 05-31-2013, 08:48 AM   #18
96smoke's Avatar
Alright well I'll look into getting a new gasket and going from there. And I'll be calling bama to figure out what could possibly cause the alternator issue.
I assume just pick up a new gasket from ford?
09:45 PM
