Help Quick! - Mustang Evolution
Old 05-18-2013, 09:15 AM   #1
ccabral14's Avatar
Help Quick!
Can I swap a 1996 mustang fuel tank, pump, and sending unit into my 2000 mustang? I found a deal for the whole 96 assembly on craigslist and I need it for my 2000, so any insight would be great ASAP
ccabral14 is offline   Reply With Quote
Old 05-18-2013, 09:29 AM   #2
1996mustang's Avatar
I dont think so since a 96 has a fuel sending unit seperate from the pump whilr on a 00 the pump is an assembly i can check quickly thougj
Old 05-18-2013, 09:39 AM   #3
ccabral14's Avatar
That would be great if you could check for me!
Old 05-18-2013, 12:00 PM   #4
You can but you'll need to convert to a return style system, new pump, new filler neck. It is not a direct replacement, 98 was the changeover year.
04:19 PM
