Removing Thermostat - Mustang Evolution
Old 05-20-2013, 01:25 PM   #1
leviz79's Avatar
Removing Thermostat
Thinking about removing my thermostat, I live in Houston so cold is not much of a factor. When I fill my reservoir on my coolant, I can drive it for a while and then it will overboard at the cap then my wearer light will come on this happens every time but there is still coolant at the low end of my reservoir tank sensor. What's causing it to overboard and my temp is always running good on the gauge, no overheating problem.
leviz79 is offline   Reply With Quote
Old 05-20-2013, 01:29 PM   #2
67mustang97's Avatar
Region: Vermont
Try replacing the thermostat they are cheap and really should be part of your cooling system.
Old 05-20-2013, 02:04 PM   #3
leviz79's Avatar
I can do that, I was really wondering if it was just necessary to have it.
Old 05-20-2013, 02:14 PM   #4
Region: Vermont
Is a Vehicle Thermostat Necessary?
Hope this link helps.
Old 05-20-2013, 06:18 PM   #5
Region: Arkansas
Very necessary. You live in Texas, the thermostat keeps your motor from overheating.
BackPressure is offline   Reply With Quote
Old 05-20-2013, 07:09 PM   #6
Sounds like you just need a new rad cap.
302 Stroker TFS Heads + Cams 11.2:1 CR
327/352 hp/tq
8111870 is offline   Reply With Quote
Old 05-21-2013, 08:22 AM   #7
Mustang936's Avatar
Get a thermostat, being in texas also a thermostat is a must.
Mustang936 is offline   Reply With Quote
Old 05-21-2013, 09:42 AM   #8
98vertgt's Avatar
You might have a manifold leak
98vertgt is offline   Reply With Quote
05:56 PM
