PLEASE. HELP. MEEEEE! - Mustang Evolution
Old 05-21-2013, 10:54 AM   #1
98StangKid's Avatar
Ok.. I posted this in the SVT section but no help... Here's my problem..
K. So I just bought a Walbro 255 pump like 2 weeks ago due to my old pump going out... (GT Supercar pump) and now my car is starting to act the same way it did before my other one went out... Surely I haven't burnt up a $200 pump in 2 weeks time.... What do I do? I know the FRPS isn't bad.. Its throwing a p0190 code. And I have an 01 Cobra.. Please help me! And thank you!
'01 Cobra
Forged Internals, Limited Slip Differential, 3:73s, Bama Tune, Pro 5.0 Short Shifter, Mach 1 Air Intake, 31 Spline Moser Axles.
98StangKid is offline   Reply With Quote
Old 05-21-2013, 01:12 PM   #2
maldog's Avatar
Region: Nevada
You are getting into a complex electrical problem it sounds like and it would have to be diagnosed in a complex manner. I wish I could help you, but your best bet is to take it to a shop that can diagnose a problem like yours. Good luck!
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 05-22-2013, 04:04 PM   #3
1996mustang's Avatar
What year cobra do you have i dont wanna assume by the username a 98?
Old 05-22-2013, 04:11 PM   #4
Imo im reading the testing procedures to p0190 sounds like your frps is either shot or you have a short in the wiring to the frps. I would try a wiggle test to the connector on the frps to see if its a bad wire contact or a break ib it. Also test to see the resistance in the frps and to see if there is a break from the frps to the pcm. This is my look into it
Old 05-22-2013, 09:22 PM   #5
Also be sure you have the right pump. 98s need pumps specific to the 98 year you just can't put a generic Walbro in there. 98s have the 99-up tank setup and a 97-down return style system with 98 specific components like 1 off fuel rails.
Old 05-22-2013, 09:28 PM   #6
+1
Old 05-22-2013, 09:58 PM   #7
Ckennedy121's Avatar
Originally Posted by 1996mustang View Post
+1
He has an 01 cobra
Ckennedy121 is offline   Reply With Quote
Old 05-23-2013, 09:08 AM   #8
Ah crap didn't see that, just saw the username. Well, then he needs to make sure he got the right returnless pump for that car. Check all fuses, check the harness, check codes, check the lines etc... If the pump isn't even priming it could be a fuse somewhere or even the stupid crash popper button in the trunk on the driver's side.
Old 05-23-2013, 10:24 AM   #9
98StangKid's Avatar
The pump I have in right now is a return style.. So I just ordered an HFP 255 return less pump.... Hopefully this fixes it...
'01 Cobra
Old 05-23-2013, 01:26 PM   #10
Yeah you need to make sure you are getting the right pump for your year car. 99-up is returnless, 97-below is return and as I said 98 is a bastard combination of both.
Old 05-23-2013, 03:37 PM   #11
98StangKid's Avatar
Yea... Hopefully putting the correct pump on will solve the problem.
'01 Cobra
09:03 PM
