96-98 pi swap - Mustang Evolution
Old 05-21-2013, 08:37 PM   #1
2300turboford's Avatar
96-98 pi swap
Who hear has done the swap. ? Can you use 87 octane ? I want feedback from ppl who have actually did the swap
Old 05-22-2013, 09:34 AM   #2
Really ? Anybody ?
Old 05-22-2013, 10:42 AM   #3
Guys, I think whst 2300 is refering to is using the earlier rotating assembly in his 01 block. Does this raise the compression ratio? I believe he said that It will make it about 10, 1 to 1, If so, is this safe to run on pump gas? And I have a question. What is the highest compression ratio that can be safely used wth these engines on pump gas? Opinions please. Thanks.
Old 05-22-2013, 11:33 AM   #4
1996mustang's Avatar
I would recommend 91 to 93 octane on it. Though i still run 87 on mine and have been for quite a time. Yes compression is higher (10.52:1 cliffy will correct me im sure of it lol) however i run 87 and every time i run 93 doesnt last long as 87. However its just me i would suggest atleast 89 since the compression bumped up due to the pi swap.
Old 05-22-2013, 11:37 AM   #5
The previous owner of mine dropped an entire PI motor into it and it runs like stock. If you are talking about just doing the PI heads/cams/intake onto a NPI block you'll bump compression up to around 10.5:1 and may or may not need a higher octane gas. I put 93 in mine all the time just to be safe although I doubt I need it. The PI is designed to run on 87. However, premium is like what $2 extra per tank? At least around here it is only about 20 cents more per gallon times usually a 10 gallon fillup from a little below 1/4 tank. This isn't enough of a difference to make any difference at all to me but I suppose if the price difference was more it might.
Old 05-22-2013, 04:46 PM   #6
I solved my problem I'm gonna grind the hump above the intake valve flush with the cc chamber to give the cc chamber more volume
04:45 PM
