Multiple symptoms need help! - Mustang Evolution
Old 05-23-2013, 07:13 AM   #1
Gobabygo67's Avatar
My 04 GT runs fine but at times it will have a rough low idle like it wants to cut off then it will idle high around 2000 rpm, also when driving at times my e brake light will pop up for no apparent reason and finally every now and then when I'm turning left or right I hear a creaking noise like something wants to break
Gobabygo67 is offline   Reply With Quote
Old 05-23-2013, 08:14 AM   #2
maldog's Avatar
Region: Nevada
It sounds like you have two different problems? I would have your front end checked out for anything wrong.
Also, have you cleaned your MAF with MAF cleaner and your TBI? This is where you should start first.
Good luck!
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 05-23-2013, 05:46 PM   #3
98vertgt's Avatar
Check your brake reservoir for low fluid for the brake light
98vertgt is offline   Reply With Quote
Old 05-26-2013, 02:49 PM   #4
02GTvert's Avatar
Ball Joint maybe. Possibly strut, guessing ball joint or bearing.. both VERY fun to do..NOT.
02GTvert is offline   Reply With Quote
08:25 PM
