Exhaust - Mustang Evolution
Old 05-23-2013, 12:21 PM   #1
Francis's Avatar
Exhaust
Throwing code p0156, just changed o2 sensor and code came back, put a o/r h-pipe on the car and mils I got from a friend.
---------- Post added at 01:21 PM ---------- Previous post was at 01:18 PM ----------
The mil that I got come off a 04 Mach 1, that wouldn't make a difference would it
Francis is offline   Reply With Quote
Old 05-24-2013, 05:42 AM   #2
cliffyk's Avatar
P0156 is a circuit malfunction code for the driver's side rear O2 sensor, it is generally associated with a wiring problem.
The MIL eliminator could have a bad connector or wiring, or the MIL eliminator itself may be defective. It is possible the O2 sesnor is bad--more about MIL eliminators and how they work here.
The only way to test is to get under there and monitor the sensor's output, both before and after the eliminator...
Old 05-24-2013, 09:28 AM   #3
Francis's Avatar
Yea my friend is going to check the mil for me this weekend and see if the wiring went bad or not. Hopefully it is cause I don't feel like buying a tuner right now for the little mods I have done to my car.
08:19 PM
