Need fuel system help !!! - Mustang Evolution
Old 05-23-2013, 02:17 PM   #1
Whtghost1979's Avatar
I have a 03-04 mach one looking at putting boost to it. I'm stuck between a rock and a hard spot on what to run as far as a fuel system I've priced return styles out and it's 1600. But I've also seen people convert to the 03-04 cobra tanks and pumps with a driver module and boost a pump. Any thoughts on what my best route would be.
Whtghost1979 is offline   Reply With Quote
Old 05-23-2013, 04:12 PM   #2
Region: Arkansas
There's no need to do a return-style fuel system unless you're over 700. The big blower (KB 2.9 Mammoth, Whipple 3.4 Crusher, etc.) cobra guys never bother with return-systems unless they're planing to pass 700.
BackPressure is offline   Reply With Quote
Old 05-23-2013, 04:38 PM   #3
So maybe switch the the cobra tank and pump system with a boost a pump and I should be good
Old 05-23-2013, 05:34 PM   #4
Region: Arkansas
I'd use a BAP if you want to push 500+
Old 05-24-2013, 07:00 PM   #5
Mzilla's Avatar
Let me know what power level you are wanting to Achieve and I can assist you. I also have a 40 amp Kenne bell BAP for sale let me know
Mzilla is offline   Reply With Quote
Old 05-24-2013, 11:00 PM   #6
600 to the tires
Old 05-25-2013, 08:29 AM   #7
Region: Arkansas
600 to the tires
You'll definitely need a BAP, as well as a Boost-a-spark and other miscellaneous things to make sure your ignition is up to the job.
Old 05-26-2013, 09:33 AM   #8
Mzilla's Avatar
600 to the tires
To get your fuel system to the safe 600 level. I would recommend twin pumps out of a Shelby cobra and a boost a pump and 60 lbs injectors and your set
Old 05-27-2013, 07:40 AM   #9
Black99Snake's Avatar
Lethal has a budget kit that should be good for what you want.
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
10:47 AM
