Brakes rattling - Mustang Evolution
Old 05-24-2013, 11:09 PM   #1
02 360R's Avatar
Brakes rattling
I took my car to a shop because I heard a rubbing sound just as I was braking. I came back about 3 hours later because they hadn't call to tell me the diagnosis and the guy told me he turned my rotors and replaced my pads-no charge. Now they rattle! Sounds like a wagon on an uneven road. Are there any recommended brake pads to correct this problem?
02 360R is offline   Reply With Quote
Old 05-24-2013, 11:12 PM   #2
DaBluedude's Avatar
That makes no sense, unless your braking is seriously compromised. Could be a bad rotor turning job... Maybe check to make sure your caliper mounting bracket got tightened properly.
2003 Mach 1
Old 05-25-2013, 08:37 AM   #3
Slow4V's Avatar
Sounds like they messed up your brakes and made it seem like they hooked you up lol
Old 05-25-2013, 11:42 AM   #4
Venomouz831's Avatar
Lol I know right
)02 Gt, Founder of WE2G
Old 05-25-2013, 12:00 PM   #5
98vertgt's Avatar
If you have the twin piston cobra brakes they have anti rattle clips. Mine did the same and I replaced them and no more noise
98vertgt is offline   Reply With Quote
Old 05-25-2013, 07:07 PM   #6
Slow4V's Avatar
Yeah mine rattle alittle ( Mach 1 here )
It's because the brembos use the C clip and pin to hold the caliper on the pads.
Which is a cool and easy design I think especially to take off but bad in a way because I've had the clip and pin come off on me and grind against my rim , coming back from the track smh
Good thing I had a pry bar in my trunk and I pryed it back on and drove home slowly
Old 05-25-2013, 08:08 PM   #7
02 360R's Avatar
The anti rattle clip is not there. I stopped by auto zone today after work and asked for the best they had. I'll put them on and hope that fix the problem.
Old 05-25-2013, 10:26 PM   #8
Slow4V's Avatar
Anti rattle clip? Never heard that before can you show a pic ?
Old 05-26-2013, 12:18 PM   #9
98vertgt's Avatar
They're little clips that go on both brake pads that keep the caliper from moving.
ID:	110510   Click image for larger version
02:29 AM
