new iac, now rpms hang between shifts - Mustang Evolution
Old 05-26-2013, 07:55 AM   #1
jdavis96gt's Avatar
Region: West Virgina
Any fixes to the problem.
Old 05-26-2013, 08:03 AM   #2
Boomdizzle's Avatar
Have you cleaned the throttle body in awhile? That's what caused that on my old fox body a few years ago.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 05-26-2013, 08:10 AM   #3
jdavis96gt's Avatar
I replaced egr valve so I sprayed TB cleaner in that side. Replaced iac and sprayed in that hole and took cai off and sprayed in there. So basically the best I could do without taking it off.
Should I take it all the way off and clean? I also cleaned mass air sensor.
Old 05-26-2013, 12:14 PM   #4
cliffyk's Avatar
Did you disconnect the battery for 5-7 minutes to clear the Keep Alive Memory (KAM)? This will force the PCM to learn new idle airs and other IAC behaviour. Let the engine idle for 15 minutes after clearing the memory. It can then take 50 to as many as 100 miles of driving for the virtual dashpot and other things to really settle down.
The KAM should be cleared whenever any intake or emissions related device is changed out.
Old 05-26-2013, 03:31 PM   #5
jdavis96gt's Avatar
Yea I disconnected battery. I haven't put no 50-100 miles on it yet. I messed around with making iac restrictor plate but kinda gave up.
Ill put some more miles on it tomorrow and see if it helps.
After it warms up, it idles at like 750 rpms. It almost feels cammed lol. But u have to slip clutch cause of hanging rpms.
Old 05-26-2013, 07:04 PM   #6
cliffyk's Avatar
Is it a 5-speed? If so 750 rpm (actually 752 in most stock tunes) is where it is supposed to idle...
Old 05-26-2013, 07:38 PM   #7
jdavis96gt's Avatar
Its a 5 speed. Other than rpms sticking/hanging its really smoother now.
Do them plates really help? I've tried making couple. Got rpms to start dropping but idle was way off, like 1200.
Old 05-26-2013, 07:56 PM   #8
cliffyk's Avatar
A much easier way to do it is to use a 1/2" copper pipe cap. Drill a hole in it (17/64" Is a good place to start) and insert it into the IAC feed tube...
More about that here ...
Old 05-26-2013, 08:02 PM   #9
jdavis96gt's Avatar
Yea thats a pretty good idea, much easier to just pull hose off. No chance off it getting sucked into TB?
Old 05-27-2013, 07:00 AM   #10
cliffyk's Avatar
It won't fit through the nipples on either the resonator or IAC inlets...
Old 05-28-2013, 06:01 AM   #11
jdavis96gt's Avatar
Had to ask lol. Thanks
02:07 AM
