New Shocks? Again!? - Mustang Evolution
Old 05-26-2013, 03:51 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
New Shocks? Again!?
So about a month ago I put new shocks on and now the same side is lower then the other and making noise again from the shocks.. Why does this keep happening? As you can see the driver side is almost a full inch lower...
ID:	110537   Click image for larger version
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 05-26-2013, 07:20 PM   #2
98vertgt's Avatar
What shocks are you running?
98vertgt is offline   Reply With Quote
Old 05-26-2013, 07:22 PM   #3
fwalck's Avatar
Shocks have nothing to do with ride height the noise may be them but idk.
fwalck is offline   Reply With Quote
Old 05-26-2013, 07:56 PM   #4
buickregal79's Avatar
Sounds like a worn spring. With a new shock it will keep your ride height somewhat higher but then to much weight takes its tool on the shock and starts to weaken. I would suggest replace rear springs, take the shocks back where you got them say they were defective so you can get a new set free (at least save your self some money there) And that should take care of that.
Shutting off the thought process is not rejuvenating; the mind is like a car battery - it recharges by running.
buickregal79 is offline   Reply With Quote
Old 05-26-2013, 08:40 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
How can I get just rear springs
2001 GT - True Blue
Old 05-27-2013, 03:44 AM   #6
Venomouz831's Avatar
On all my past mustangs the driver side has always been lower than the other. Only way to fix it was coilovers
)02 Gt, Founder of WE2G
Old 05-27-2013, 05:27 AM   #7
02GTvert's Avatar
Even my eibach coil over my driver is lower in the rear when its all the way down..which sucks because that's where I want it. But I plan on putting my battery over the pass rear and hope its enough to do the job.
02GTvert is offline   Reply With Quote
Old 05-27-2013, 09:38 AM   #8
Mine doesn't have that issue, but if its that common you can get a spring with a higher rate so it can compensate for extra weight or misaligned something apparently.
Old 05-27-2013, 09:55 AM   #9
Rm360's Avatar
Hey guys!!! Here is a very good read about suspension geometry, this gives you an idea of why the suspension sits uneven in the rear http://www.moddedmustangs.com/forums...ion-guide.html
09:23 AM
