My speedo is off 8 mph - Mustang Evolution
Old 05-26-2013, 08:06 PM   #1
Hey guys I bought my 2000 GT from a guy who had 4.10 in and a module to correct the speed. The box was from Dallas mustang.com but I smoked the read end out so I have ford put 3.55 in. Now the mph are off about 8 mph. Ie when my speedo says 60mph I'm really going 68 mph. I tried to switch some of the switches on the module but no luck. Any help with this would be greatly appreciated.
Patrickandberry is offline   Reply With Quote
Old 05-26-2013, 08:14 PM   #2
MidnightBlueGT's Avatar
Handheld tuner you can input your gear ratio
Old 05-26-2013, 08:15 PM   #3
Billymich's Avatar
Wow how do I convert my speedometer to MPG mine is always stuck on MPH?
Old 05-26-2013, 08:17 PM   #4
Do you have a good one in mind. The sct seems like a good deal. I have the binary one already but as I switch the switches around it won't correct it.
---------- Post added at 10:17 PM ---------- Previous post was at 10:15 PM ----------
Damn iphone auto correct
Old 05-26-2013, 08:20 PM   #5
Billymich's Avatar
^_=
Old 05-26-2013, 09:08 PM   #6
What?
Old 05-26-2013, 09:10 PM   #7
In the title it said mpg not mph, I corrected it
Old 05-27-2013, 09:15 AM   #8
cliffyk's Avatar
Go to Dallas Mustangs' website, they have the programming instructions posted there...
Old 06-21-2013, 10:36 PM   #9
Cliff,
I followed the instructions but still nothing, when I switch the thing to 3.55 gears its way off
Old 06-21-2013, 10:39 PM   #10
FortyBrandon's Avatar
Rear gears has been changed!!!!!!!!!
FortyBrandon is offline   Reply With Quote
Old 06-21-2013, 10:41 PM   #11
Yes. It can stick with 3.23 then replaced with 4.10 and the speed module then I replaced them with 3.55 and changed the speed mod and it goes nuts
Old 06-22-2013, 06:54 AM   #12
cliffyk's Avatar
Originally Posted by Patrickandberry View Post
Cliff,
If you are certain you had the switches set properly, for 3.27 -> 3.55 the 10-position DIP switch should be set to 0010001011, where 0 = off and 1 = on, then perhaps the unit is defective? IDK.
What are the switch positions for the 4.10 gears? It should be 0010100000...
Old 06-22-2013, 06:55 AM   #13
You are correct I'm going to give it another look soon. Have to find out where my anti freeze is leaking first
02:30 AM
