sensors at back of head - Mustang Evolution
Old 05-27-2013, 02:54 PM   #1
Hey,
getting ready to reinstall my engine in the Cobra,..but there are two small one wire sensors (one on each head at the back) bolted to the rear of each head. The driver side connector is broken and allows the wire to push through the connector.
What are these things?
I'd rather replace it while it's out before installing the engine.
2003 Zinc yellow Cobra (Rescued shelter dog)
C.A.I.; 2.8 upper pulley;Non-catted off road pipes w/ Mac flowchamber, Flowmaster cat back. EGR delete; Head cooling mod;
My 5.0 feature:http://www.mustang50magazine.com/fea...d/viewall.html
mike1157 is offline   Reply With Quote
Old 05-27-2013, 04:26 PM   #2
CodyNelson's Avatar
Region: West Virgina
Someone correct me if I'm wrong but I believe they are the cam sensors
Old 05-27-2013, 05:08 PM   #3
1996mustang's Avatar
Cam sensor would have 2 or 3 wire depending if hall effect or something else i cant remember the name for. A one wire would usually be probably a temp sensor or probably in your case knock sensors if i remember correctly. Im sure someone will bring light to this ill be verifying wat they are now as well
Old 05-27-2013, 06:52 PM   #4
They're not cam sensors, I know that much.
This is what I'm talking about:
Old 05-27-2013, 07:02 PM   #5
they are capacitors for the ignition, ignition transformer capacitor is their names from my research on all data. they affect obviously ignition, i.e. coil pack signal.
Old 05-28-2013, 02:38 AM   #6
Slow4V's Avatar
Cam sensors are in the front by the power steering pump and heads
Old 05-28-2013, 05:11 AM   #7
cliffyk's Avatar
They are air-gap capacitors that filter high frequency "noise" generated by the COPs primary circuit from the car's electrical system--preventing that noise from interfering with the PCM, cluster microcontroller, audio system, etc...
05:56 PM
