Hooking up amp - Mustang Evolution
Old 05-27-2013, 05:19 PM   #1
shawn.velez36's Avatar
Hooking up amp
Anyone know how to connect an amp to the ignition?
shawn.velez36 is offline   Reply With Quote
Old 05-27-2013, 05:20 PM   #2
Promackiller34's Avatar
Hi
Promackiller34 is offline   Reply With Quote
Old 05-27-2013, 05:22 PM   #3
Originally Posted by Promackiller34 View Post
Hi
Your an idiot!
Old 05-27-2013, 05:24 PM   #4
v8pony's Avatar
Your an idiot!
Lmao looks like we may just have one of those "join up, post 50 random/pointless posts, get the AM discount and bounce" type of guys lol..
2002 5spd GT
Feb 2013 Mustang of the Month
Old 05-27-2013, 05:26 PM   #5
Nah lol he's my friend, just being dumb
Old 05-27-2013, 05:45 PM   #6
v8pony's Avatar
Lol hahaha cool just making sure, have seen many of them pop up lately, any luck with that amp? My Mach 460 gave me such a headache that I said screw it and had somebody make it all right for me, good luck with it..
2002 5spd GT
Old 05-27-2013, 05:46 PM   #7
No, we have hooked up everything else just can't get it hooked up to the ignition....don't even know where to start. Probably just going to take it to best buy and have them do it.
Old 05-27-2013, 06:34 PM   #8
Ewww eff those hack jobs at Best Buy. Not sure what you are trying to do, all the plugs should mate up unless you are looking to do something with the wiring. Maybe I am missing something. Or you could just delete the Mach system as even a basic good aftermarket headunit and speakers with the factory crap amp bypassed will sound better.
Old 05-27-2013, 07:17 PM   #9
Slow4V's Avatar
Just the the amp kit , comes with eveything you need
Easy install and gives directions
Old 05-27-2013, 07:28 PM   #10
MidnightBlueGT's Avatar
^ probably one of the easiest ways there are other alternatives though.
Lol that kids post made me laugh.
Old 05-27-2013, 07:32 PM   #11
Mustang2004Gt's Avatar
Wait you get a discount after getting 50 posts?
Mustang2004Gt is offline   Reply With Quote
Old 05-27-2013, 07:34 PM   #12
Yes, once you get there pm one of the am guys
Old 05-28-2013, 09:52 AM   #13
Well I have installed everything else, just need to connect the wire to the ignition
Old 05-28-2013, 10:59 AM   #14
So your trying to hook up the (REM), the wire that turns your amp on when you turn your key, from your amp? Factory or aftermarket head unit? Do you have the mach 460? Aftermarket radios have a wire on the back of them for this, usually blue. With the Mach 460, on the back of the radio, try connecting to the black/pink wire.
2011 Grabber Blue GT
Boss intake, BBK o/r x-pipe, Bama tune, Pypes axle backs, AM short throw shifter, AEM CAI
Gixx is offline   Reply With Quote
Old 05-28-2013, 04:22 PM   #15
Yes! I have the Mach 460. Black/pink huh ill give that a try. Thanks alot man!!
Old 05-28-2013, 04:28 PM   #16
Mfore33's Avatar
If you have a multimeter use it to find the ignition on hot side of a fuse over 15 amp and use a tab connector
Old 05-28-2013, 08:47 PM   #17
Just use a probe light for that honestly. I'd run an inline fuse though.
Old 05-28-2013, 09:04 PM   #18
Ok I have it wired to my ignition now, but my amp isn't getting any power (before y'all ask, yes it is connected to the battery). Think it might be the fuse but not sure...
Old 05-29-2013, 03:05 AM   #19
Mfore33's Avatar
You have to connect the remote wire as well
Old 05-29-2013, 03:21 AM   #20
Slow4V's Avatar
Run the remote wire to a fuse that only turns on power when you turn the key on
Old 05-29-2013, 08:59 AM   #21
Can someone describe how to do that? I'm kind of a rookie when it comes to wiring :/
Old 05-29-2013, 10:15 AM   #22
You should have a ground wire, from the amp to bare metal in your trunk. You should have a power wire run from your amp to the positive side of your battery. And you should run a remote wire from your amp to the black and pink wire behind your radio.
Old 05-29-2013, 12:05 PM   #23
Oh nvm I have done all that already. Still no juice in the amp
Old 05-29-2013, 06:08 PM   #24
I think i found my problem
02:47 PM
