A/C doesnt blow cold - Mustang Evolution
Old 05-27-2013, 07:00 PM   #1
XSlashDashX's Avatar
I replaced the A/C Sensor and still not cold air
I checked all fuses and replaced 2 fuses and still no go
Check voltage and I get voltage in places. Could the PCM be fried or what?
1998 Mustang GT 5 speed is the model.
Old 05-27-2013, 07:03 PM   #2
fastmustangs1's Avatar
Did u check ur freon in the system.
fastmustangs1 is offline   Reply With Quote
Old 05-27-2013, 07:14 PM   #3
v8pony's Avatar
+1 freon
2002 5spd GT
Feb 2013 Mustang of the Month
Old 05-27-2013, 07:48 PM   #4
BigB227's Avatar
Happened to my stang and it was the CCRM (constant control relay module) it's located in the passenger side fender well
BigB227 is offline   Reply With Quote
Old 05-27-2013, 09:02 PM   #5
I got plenty of freon. Not to little and not to much to ruin the compressor.
---------- Post added at 09:02 PM ---------- Previous post was at 08:59 PM ----------
How do I replace the CCRM?
Old 05-27-2013, 09:54 PM   #6
Is the compressor kicking on? Could be a shot compressor, could be a bad clutch on said compressor.
Old 05-27-2013, 11:08 PM   #7
Has to be the CCRM. Everything else is fine. Where do I find CCRM? I found one on eBay but they cost A lot. That normal?
Old 05-28-2013, 09:23 PM   #8
BigB227's Avatar
Go to auto zone or something but they don't call it a CCRM they have it listed as BCM body control module or body computer module I can't remember
Old 05-29-2013, 06:19 AM   #9
How much does it cost? Can I replace it myself?
Old 05-29-2013, 08:23 AM   #10
CodyNelson's Avatar
Region: West Virgina
FYI do NOT put freon in your car lol. Freon is a DuPont brand household refrigerant. You want r134a refrigerant.
Old 05-29-2013, 08:37 AM   #11
I have plenty of freon. Checked with a gauge.
Old 05-29-2013, 11:10 AM   #12
Okay. Got on autozone. Is it the $110 bucks?
Old 05-31-2013, 11:50 AM   #13
Bump.
Old 05-31-2013, 12:54 PM   #14
FortyBrandon's Avatar
Did you turn the knob to the blue side?
FortyBrandon is offline   Reply With Quote
Old 05-31-2013, 02:05 PM   #15
BigB227's Avatar
Yes that sounds about right! And yes just jac your front end up take your passenger side wheel off and take the inner fender guard and it's up towards where your CAI comes through
Old 05-31-2013, 02:38 PM   #16
Yeah. I saw it. Just replace that and it should work? I notice today when I switch from vent to floor or to max a/c it will take awhile to switch between them. Is that normal?
Old 05-31-2013, 02:39 PM   #17
BigB227's Avatar
Yup as soon as its replaced it'll all work and make sure the negative terminal is off!! And yeah that's a symptom
Old 05-31-2013, 06:30 PM   #18
CodyNelson's Avatar
Not exactly. When you pull the lines off the compressor you will lose all your r134a along with the oil in the system. You will need to oil the new compressor and then go to your local Autozone and get 2 cans of A/C Pro. It's in a big black can and is bar none the best stuff on the market. Runs $45 for a big can with gauge and then $25 for a second smaller can to finish the job. Our cars hold 36oz of refrigerant. One big can and one small will put you at 32oz. I HIGHLY recommend you grab a 3oz can of Super Seal as well (~$28). Put that in before the r134a and it will go through and seal up any holes in the rubber AND metal lines as long as they are smaller than the opening of the tip of an ink pen.
Old 05-31-2013, 07:29 PM   #19
Thanks! I'll see if it works. It's hot in Texas and I need the a/c lol
Old 06-01-2013, 09:50 PM   #20
BigB227's Avatar
I was talking about the CCRM not messing with the actual compressor
Old 06-02-2013, 06:37 PM   #21
Can I also buy this part from oreillys?
Old 06-03-2013, 05:57 PM   #22
BigB227's Avatar
I don't see why not
---------- Post added at 07:57 PM ---------- Previous post was at 07:56 PM ----------
It will be a special order part regardless
Old 06-03-2013, 06:23 PM   #23
I got the part. This thing is huge.
Old 06-03-2013, 06:44 PM   #24
BigB227's Avatar
Pic??
Old 06-03-2013, 08:57 PM   #25
Is that it?
ID:	112044   Click image for larger version
Old 06-03-2013, 09:28 PM   #26
gqsmash's Avatar
Never known anyone else to be so educated!!! Hahaha finally!!!
gqsmash is offline   Reply With Quote
Old 06-03-2013, 11:01 PM   #27
BigB227's Avatar
Is that it?
That would be it! Lol
Old 06-03-2013, 11:12 PM   #28
Sweet!
Old 06-04-2013, 08:08 AM   #29
Do I need to disconnect the Battery when changing out the module?
Old 06-04-2013, 09:17 AM   #30
BigB227's Avatar
Yes it's absolutely necessary to disconnect the negative before touching the part
Old 06-04-2013, 09:20 AM   #31
Thanks!
Old 06-04-2013, 10:09 AM   #32
CodyNelson's Avatar
Haha I know!
Old 06-04-2013, 10:44 AM   #33
Region: Arkansas
Thank you! Ugh, I hate people that call refrigerant "freon".
I filled my car up a few weeks ago with the Auto Zone DIY thingy and the cashier asked if I was filling up my car's freon. I said "no? I don't have any freon." and left with him looking at me like I was retarded or something.
BackPressure is offline   Reply With Quote
Old 06-04-2013, 10:59 AM   #34
Lol.
Old 06-04-2013, 02:10 PM   #35
gqsmash's Avatar
Hahaha right!! And they probably went and told people you were retarded!! Ignorance is amusing!!
12:25 AM
