Leak :.( - Mustang Evolution
Old 05-27-2013, 07:05 PM   #1
Mflores14's Avatar
Leak :.(
Got a leak in under the thermostat housing and it's leaking coolant alot heard I'm sposed to replace the manifold but that's too much money what do you guys think I should do ?
Mflores14 is offline   Reply With Quote
Old 05-27-2013, 08:10 PM   #2
Billymich's Avatar
Was it overheating? Are you burning coolant, as in check your exhaust.
Old 05-27-2013, 09:56 PM   #3
Looks like you got a metal crossover so that probably isn't the issue. If its coming from the intake the intake is going to have to come off. "That's too much money" is going to equal WAY more money when you fry something. The intake is very easy to remove with hand tools and plenty of how-tos online. I'm not saying that the intake has to come off 100% but isolate where it is coming from and go from there.
Old 05-28-2013, 05:36 AM   #4
cliffyk's Avatar
The two most common failures of the "metal crossover" intake manifold are breaking of the nipple for the heater core outlet (passenger side rear), and erosion of the retaining groove for the formed gasket seal in the crossover/thermostat housing to manifold plastic flange joint.
The inner wall of the retaining groove erodes and no longer contain the gasket, which pops out into the coolant passage, it not longer seals as it should and coolant leaking out is the result.
From the underside of the manifold it looks like this:
A new manifold is the simplest solution, however being retired and cheap I repaired mine with JB Weld:
If you choose this route proper surface preparation and degreasing is essential to success. I can fully explain how I did it if anyone is interested.
This was in February of 2011, at which time I also ordered a new FRPP manifold "just in case" the JB-Weld repair did not work. The new manifold is in my attic and of course now that it is there the repair will never fail...
10:36 AM
