Tire size - Mustang Evolution
Old 05-29-2013, 07:49 AM   #1
96smoke's Avatar
Tire size
I've got the 03 GT premium wheels and my rears need to be replaced and I'm wondering if anyone has ran a 275/35/17 on these or if it can be done?
96smoke is offline   Reply With Quote
Old 05-29-2013, 08:25 AM   #2
cliffyk's Avatar
The stock '03 wheels are 8" wide, no tire maker would recommend that 275/35-17s be run on 8" wheels. That said, while I have not heard of anyone using 275/35s on the 8" wheels (see below) many have run 275/40s with no problems.
Also, why 275/35? They are 4% smaller outside diameter than the stock 245/45 tires and will mess up your speedometer (it will read fast). 275/40-17s are very nearly the same diameter as the stock tires and will not mess up the speedometer...
Old 05-29-2013, 10:15 AM   #3
96smoke's Avatar
That's what I needed to hear. Because I had no clue which tire size to pursue, and 275/35 was mentioned to me by someone so that's what I kept on my mind. But I'll deff be looking into 275/40 now as long as no issues will occur
Old 05-29-2013, 11:23 AM   #4
cliffyk's Avatar
To clarify, I didn't say "no issues will occur", I said "many have run 275/40s [on 8" wheels] with no problems"; and that it would be going against tire manufacturer's recommendations...
Old 05-29-2013, 11:30 AM   #5
I had 275/40/17s mounted on stock 8" wide wheels. The sidewall really stuck out and the ride wasn't the greatest and traction honestly really didn't improve. I would stick with 255s on 8" wide tires which is what came OEM on the 94/95 Cobras even though everything else got 245s.
I personally hate the stock wheels on Mustangs, the backspacing and only being 8" makes the rear tires look ridiculous from the back with them being in from the edge of the fender pretty far. I'd go get a set of 10.5" wide rims for the back and throw some 295-315 wide tires on them. Looks a hundred times better and you get some real meat out back.
Old 05-29-2013, 11:46 AM   #6
cliffyk's Avatar
^+1, That would be the direction I would (did) go as well:
Old 05-29-2013, 11:52 AM   #7
This is why I always like the wide rear tires
Screw the narrow tucked in tires that come stock.
Old 05-29-2013, 12:20 PM   #8
you can fit a 275 on an 8" wide tire but they generally look far to bloated~ it all depends on the brand of tire, some makers are more narrow than others (you would figure mm is mm.... but its not to tire manuf )
Old 05-29-2013, 12:23 PM   #9
96smoke's Avatar
I mean I agree 100% but I like these rims and got them for a steal and I don't necessarily want to go about getting a new set. Not in my budget I was told I can get them widened and that its pricey but it's worth it if you like the rims
Old 05-29-2013, 02:23 PM   #10
I would not waste the money to get those rims widened. I mean if you REALLY like them but there are ones that, IMO, look way better and you can probably get them shipped to your door for less than you'd pay to ship your wheels out to someplace to get them widened and ship them back.
In the meantime, if I were you I'd get some 255/45/17 tires, wheel spacers to at least put the tires further out towards the fender so it isn't so narrow and run like that for awhile.
Old 05-29-2013, 02:47 PM   #11
cliffyk's Avatar
Generally alloy wheels can only be widened on the inside, meaning that wheel spacers may have to be used to make them clear. Also doing it properly will cost more than a new wheel--beyond that I personally would not ride in a car with widened alloy wheels, even if I was the one that widened them...
Old 05-29-2013, 04:29 PM   #12
Count Dragula's Avatar
With 10.5 wheels you can do magic
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 05-29-2013, 05:32 PM   #13
Slow4V's Avatar
Yes you can run 275/45/17 on those wheels, don't listen to anyone who says you can't.
I put them on all the time
Old 05-29-2013, 05:55 PM   #14
Nobody said you couldn't. Although the 275/45 makes them bigger than stock diameter. 275/40 is stock diameter and as I already said I've ran those myself on 8" rims. It just rides worse and you really don't get any more traction. Also looks kinda eh with the sidewall bulging over the rim like crazy.
05:46 PM
