P1443 - Mustang Evolution
Old 05-29-2013, 07:52 AM   #1
96smoke's Avatar
P1443
So this code is popping up now. I have a 96 gt.
I have a tuner and when I had the bama tune on, it still popped up. To my knowledge this is an evap code and is saying something is wrong with the purge flow canister? Heard it's common on 94-98s just wanting some insight on it and knowing the right path to take to fix it
96smoke is offline   Reply With Quote
Old 05-29-2013, 08:26 AM   #2
cliffyk's Avatar
Here is what the shop manual says about P1443...
Old 05-29-2013, 09:05 AM   #3
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
P1443 - Very Small Or No Purge Flow Condition. A fuel tank pressure change greater than a minus (-) 7 inches of H 2 O in 30 seconds has occurred with purge (fuel vapor) flow less than 0.02 pounds per minute.
*Blocked fuel vapor hose between EVAP canister purge valve and FTP sensor.
*Blocked fuel vapor hose between EVAP canister purge valve and engine intake manifold.
*Blocked vacuum hose between EVAP canister purge valve-solenoid and engine intake manifold.
*EVAP canister purge valve stuck closed (mechanically).
This is all taken from CliffyK's link and is 100% correct. This is what causes the P1443 code! To fix it, just like Cliff said "Check for blockages between the fuel tank, EVAP canister purge valve and engine intake manifold. Check obstructions in the EVAP canister purge valve diaphragm and ports."
I hope this helps. Please let us know if we can be of any assistance or if you have any questions! Our Mustang Experts are here Monday-Friday from 9AM-9PM EST and Saturdays from 9AM-5:30PM EST. If you want to hit them up, their number is 866.727.1266.
-Dan
Old 05-12-2014, 06:16 PM   #4
96NYCGT's Avatar
Send a message via AIM to 96NYCGT
Name:	ImageUploadedByMustang Evolution1399940154.520309.jpg
I just got my light on and after a few mile the light go away
96NYCGT is offline   Reply With Quote
09:40 AM
