Twin Turbo or Vortec Super Charger - Mustang Evolution
Old 05-29-2013, 12:39 PM   #1
BeasGT's Avatar
So what do you think guys?
Two of my buddies are selling twin turbo set up & a supercharger set up.
BeasGT is offline   Reply With Quote
Old 05-29-2013, 12:44 PM   #2
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
What brands and for how much?
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 05-29-2013, 12:58 PM   #3
MidnightBlueGT's Avatar
If you can afford the supporting mods go tt all day.
Old 05-29-2013, 02:07 PM   #4
Is the TT a Hellion? Gotta know what brand it is. In any case the Vortech will be cheaper, easier to install, less maintenance and on the stock motor will make just as much power as the TT kit.
Also, if your car is a stick I'd go with the supercharger. IMO, turbo Mustangs should all be automatics. Automatics and turbos go together like peas and carrots.
Old 05-29-2013, 09:29 PM   #5
1lowGT's Avatar
Someone on here told me Ellison east a good brand. And is it centri or twin screw?
Old 05-29-2013, 09:34 PM   #6
McNassty's Avatar
Dude sorry but twin turbo all day, that will make tons more power than a supercharger
McNassty is offline   Reply With Quote
Old 05-29-2013, 09:44 PM   #7
McNassty's Avatar
And you will want to build your bottom end up on either application and turbo is safer either way you go
Old 05-29-2013, 09:55 PM   #8
McNassty's Avatar
Supercharger forces air in turbocharger sucks it through
Old 05-29-2013, 09:59 PM   #9
On the stock block he is limited to around 450whp MAX and should probably keep it under 425whp to be safe. So in that respect either one is fine on the stock block.
Depends on his goals, as I said a solid 400whp is totally safe and doable with a good tune on a stock block. Either blower will get you there
Do go on about how a supercharger forces air in and a turbo sucks it through...
Old 05-29-2013, 10:06 PM   #10
McNassty's Avatar
I'm sorry I forgot how you and diesel are the great know it alls
Old 05-29-2013, 10:10 PM   #11
So no elaboration on how a Turbo sucks air but a supercharger forces it in? Because they both do both and a centrifugal supercharger is identical in operation to a turbo with the obvious exception that one is belt driven and one is exhaust driven.
Old 05-29-2013, 10:13 PM   #12
McNassty's Avatar
Exactly exhaust driven as in sucks air through the engine (turbo), forces air through the intake (supercharger)
Old 05-29-2013, 10:14 PM   #13
Um, no.
I'm glad we have people like you giving advice...
Old 05-29-2013, 10:15 PM   #14
McNassty's Avatar
I'm scared that we have people like you chiming in on every thread
Old 05-29-2013, 10:17 PM   #15
Lol, go read up on how a turbo works and get back to me and whoever else. Turbos do not suck air through the engine.
Old 05-29-2013, 10:18 PM   #16
+1
Old 05-29-2013, 10:20 PM   #17
ColeJohnson's Avatar
+1
2016 Comp Orange GT (current)
Old 05-29-2013, 10:21 PM   #18
I think he was actually saying that a turbo sucks air through the engine to make more power? Gotta love internet racers/info recylcers.
Old 05-29-2013, 10:30 PM   #19
I think I understand the thought process. Turbo runs off exhaust so you could argue that it creates a vacuum to pull air through the engine, out the exhaust, back into the turbo.. Or something. Idk.
Old 05-29-2013, 10:37 PM   #20
McNassty's Avatar
So the exhaust gases that cause the turbine to spin which cause more air to flow through the intake which causes more vacuum through the exhaust is the same as an intake ran by a belt which causes the S/C to force more air through the intake is pretty much the same?
Old 05-29-2013, 10:41 PM   #21
No... a turbo creates positive PSI run off waste exhaust gas from the headers. There is no vacuum whatsoever in the turbo system and this is illustrated in the fact that you can easily bog the motor between shifts.
As I said, the principle of a supercharger and turbocharger are the same. Both force air into the motor from the outside. More air=more fuel=more power provided the motor/tune is good for it. Just happens that one is driven by pressure from the exhaust and one is driven by a belt from the accessory drive.
---------- Post added at 12:41 AM ---------- Previous post was at 12:38 AM ----------
There is no vacuum in the exhaust. Exhaust is forced out on the exhaust stroke of the engine, it is all positive pressure.
Old 05-29-2013, 10:43 PM   #22
+1
Old 05-29-2013, 10:49 PM   #23
+1 lol
Old 05-30-2013, 05:58 AM   #24
White03GT's Avatar
Id rather have a turbo set up due to it being a little easier on your internals seeing is how your not in constant boost. But then again once your in it there's a chance it can freak and cause more damage on the internals. Turbos don't take power to make power but require more maintenance. Your call really, if you're staying with stock internals I'd go with the centrifugal. Easier to maintain and won't have to worry about it spiking. I know I contradicted myself but **** it ha
White03GT is offline   Reply With Quote
Old 05-30-2013, 07:19 AM   #25
Lol yeah that is a great benefit to a turbo, they take a little power to make big power (not NO power but it is not very much at all). Figure a superhcharger takes 15% of the total output to power itself and that number climbs the more power you make. However as I said, a supercharger is less maintenance, easier to install, cheaper and I'd rather have one on a stick car than a turbo. IMO, turbo is for all out power in a straight line and should be paired with a stalled automatic. Supercharger can also make a ridiculous amount of power, just look at the YSI guys running just silly numbers with those blowers and the Mammoth KB Cobras. They just aren't as efficient as a turbo.
Also, once you get a turbo welcome to the world of waiting in the car for 2 minutes everytime you stop somewhere before you can turn it off and get out. If you don't, the oil lines will begin to coke up and goodbye turbo after a little while. There are turbo timers but if you are like me you'll worry that it won't turn off for some reason and you'll have a car idling in the hot sun in a blacktop parking lot for hours while you are inside at work or wherever... no thanks. That is just me being OCD though lol.
Old 05-30-2013, 11:01 AM   #26
Ewokjax95's Avatar
Centri blower all day. Would be nice to know what size blower the Vortech is though. I personally believe Procharger>all, but thats irrelevant. In either of these situations, Remember your weak sauce stock drivetrain.
Ewokjax95 is offline   Reply With Quote
04:26 PM
