HELP!! 04 mustang went dead?? - Mustang Evolution
Old 05-30-2013, 12:05 AM   #1
black94stallion's Avatar
I have an 04 mustang gt that only has 57xxx miles on it and when I was about to turn on my road I pushed my clutch in and my battery light came on then right after my check engine light came on and the car went dead... I then started it up and drove to the house and plugged my programmer up it didn't read anything I'm thinking it my be the alternator... I have one 12" sub and an 800 watt amp but I wasn't playing music with a lot of bass at the time what do y'all think?!
black94stallion is offline   Reply With Quote
Old 05-30-2013, 12:10 AM   #2
Slow4V's Avatar
Sounds like loose battery terminal
Old 05-30-2013, 12:26 AM   #3
Thanks bro ill check it first thing in the morning!
Old 05-30-2013, 01:37 AM   #4
Terminator's Avatar
Yea most likely loose terminal
Terminator is offline   Reply With Quote
Old 05-30-2013, 07:39 AM   #5
jjsg09's Avatar
Check the cable that attches to the top of your alternator with the rubber boot. Mine snapped off last night ( threads and all ) and my car died.
Old 05-30-2013, 08:28 AM   #6
Mustang936's Avatar
Yup most likely a problem with the charging system or the battery.
Mustang936 is offline   Reply With Quote
Old 05-31-2013, 05:46 PM   #7
I checked everything and everything was tight... It hasn't done it again when it happened I felt like I kicked something under the dash like the fuse box or something but knock on wood everything is working fine
Old 05-31-2013, 05:54 PM   #8
Mile high JDF's Avatar
Do you have a sound system with a subwoofer?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 05-31-2013, 07:04 PM   #9
Happened to me before, I unplugged my battery for 5 minutes, plugged it back in and fired it up. Hasn't happened since.
Old 06-01-2013, 06:20 AM   #10
Yea I have one 12" with an880 watt amp but it shows the alternator is charging properly with the sub on
---------- Post added at 07:20 AM ---------- Previous post was at 07:19 AM ----------
That's strange I wonder what it was
Old 06-01-2013, 07:53 AM   #11
Do you have any sort of on/off switch tied into the amp turn on wire? I ran into an issue where my car just wouldn't start even thought the battery, starter, and alternator were good. It ended up being that my subwoofer would slowly drain the battery because my deck wouldn't shut off right away after turned the key off.
Old 06-01-2013, 11:08 AM   #12
No my radio and everything shuts off when I turn off my car
11:28 AM
