5.4 question - Mustang Evolution
Old 05-30-2013, 03:52 PM   #1
2002VertGT's Avatar
5.4 question
Would a 5.4 3v be worth rebuilding to swap into a new edge? Looking at having to replace my f150 motor. Didn't know if I should keep it to rebuild for the stang or send it back for my $500 deposit.
4.10 Gear/RPM thread
Old 05-30-2013, 04:42 PM   #2
Now you're talking my language... I've been looking into this swap a bit. I like it just because of the extra displacement. I mean come on. 281 cubic inches?!?!!?? Im more accustomed to slightly larger engines. I believe there is a thread on here somewhere regarding this swap. It will be interesting to here everyone's opinion on this...
Old 05-30-2013, 05:06 PM   #3
White03GT's Avatar
A buddy of mine did this. Except it was a full bolt on and cammed 5.4 2v in his 02 gt. pretty sweet
White03GT is offline   Reply With Quote
Old 05-30-2013, 08:21 PM   #4
AgentOrange's Avatar
Everything bolts up, accessories are the same, etc etc. Only issues are deck height and intake. Truck intakes don't flow enough.. only way to run headers is have custom ones made to the best of my knowledge. I'll be doing this swap if my stock mill lets go.
AgentOrange is offline   Reply With Quote
Old 05-30-2013, 08:36 PM   #5
2002VertGT's Avatar
I mean, I know it can be done. But, IS IT WORTH IT to keep this 3v and rebuild it? I know there will be parts I have to buy and maybe some parts that need custom made. But is it worth it? Or should I just return it for my deposit back and continue with my forged 4.6 2v plans.
Old 05-30-2013, 08:39 PM   #6
Its totally your call. Depends on what kind of deal you can get on either setup. Without supporting parts, the 5.4 won't really outperform a 4.6.
Old 05-30-2013, 09:50 PM   #7
If you're going to do a 5.4L, do a 2V with the TFS heads. With that said, the intake selection is either out of production hard to find (and not that great) pieces or adapter plates (also getting hard to find anymore) to run a 4.6L intake but there are issues with injector spray patterns and ports matching up with those...
I'd personally stick with the 4.6L... you don't need a ton of cubic inches to make great power anymore I mean look at the Coyote. 302 cubic inches on that thing and it outruns the LS motors that are "traditional" big cube powerplants. There are plenty of NA 4V cars making in the high 300whp range and honestly all it takes to make stupid power with a 4.6L is to add boost. Boost turns the 4.6L into a complete monster and with the right supporting mods the sky is really the limit.
2000 Mustang GT Steeda #0048
Old 05-30-2013, 10:10 PM   #8
2002VertGT's Avatar
I have a pro charger...just have this opportunity so I wanted to ask
Old 05-30-2013, 10:14 PM   #9
I'd turn around and send your blown truck motor back for the $500 and put that $500 towards a second block/forged crank and get started on that. I picked up a very clean Teksid block and the OEM Cobra crank for $250 locally so there are deals out there.
Old 05-30-2013, 10:35 PM   #10
2002VertGT's Avatar
How much lighter is the teksid block?
Old 05-30-2013, 10:47 PM   #11
BigB227's Avatar
I might be wrong but I believe the teksid block weighs about 85 pounds
BigB227 is offline   Reply With Quote
Old 05-30-2013, 11:07 PM   #12
Teksid is around 85lbs, the iron block is 150-160lbs, I think 154 is the dead on number but its close. No idea why in hell people don't always use the Teksid block or at least the WAP in new builds. Taking a solid 70lbs off the nose is a pretty big deal in these cars. Granted it is much easier to find an iron block and they are often free but you don't have to pay very much for a good aluminum modular block and its honestly a drop in the bucket when you are talking about a $thousands shortblock.
Old 05-31-2013, 01:16 PM   #13
My idea for a 5.4 swap is to use a complete Lightning engine. To avoid some of the aforementioned pitfalls. I realize that engine technology has come a long way in the past 30yrs or so. They're so much more efficient. There is a ceiling though. At some point, you will add all the boost and every trick in the book to the cubic inches available and the only way to add additional power is to add displacement. A good example is the 5.8 in the GT 500. If Ford thought that 5.0 litres would have powered that car and lived through the warranty period they would have used it. The technology changes but the principals have been the same for the last 100+ years. As far as the 4.6, it sounds like that aluminum block is the way to go. 85 lbs is pretty light. Weight reduction is just as good as power. Sometimes better. Definitely cheaper and easier. But if you want to make more power you need more displacement...
Old 05-31-2013, 01:20 PM   #14
99mustang99's Avatar
Do a 2v to 4v head swap(; with forged internals and other goodies
99mustang99 is offline   Reply With Quote
Old 05-31-2013, 01:20 PM   #15
Lightning swaps have been done, awesome setup. I'd still want forged rods if I went through the trouble, though.
Old 05-31-2013, 01:27 PM   #16
Definitely
11:00 PM
