need help car wont start! - Mustang Evolution
Old 05-31-2013, 10:52 AM   #1
Doe_Rae_mi's Avatar
Hey guys when I got home today I tried cranking my car up. But it was like my battery was dead. NO electricity whatsoever, so I jump it off and went to autozone, they checked my batttery and said my alternator and battery was good, this makes no since considering it was as it it was dead 10 minutes prior
Old 05-31-2013, 10:57 AM   #2
Brandon280's Avatar
Bad connection on the terminal maybe??
Brandon280 is offline   Reply With Quote
Old 05-31-2013, 11:05 AM   #3
Doe_Rae_mi's Avatar
We thought tht but we cleaned it and everything, also the fact that it was dead and jumping it off cranked it up proves it wrong it, I mean my situation makes no sense at all
Old 05-31-2013, 12:47 PM   #4
Doe_Rae_mi's Avatar
Also my check Engine light is randomly off,it had been on since I put my off-road pipes on
Old 05-31-2013, 01:20 PM   #5
03RedfireGt's Avatar
Bad connection at the alternator, maybe. Also if you un hook the battery the check light will go out. But it will come back on eventually.
03RedfireGt is offline   Reply With Quote
Old 05-31-2013, 01:29 PM   #6
Doe_Rae_mi's Avatar
It's Nothing to do with the alternator because the car has no powrr at all, also battery is 2 days old
Old 05-31-2013, 01:34 PM   #7
Tyoung68's Avatar
Check grounds same thing happened to me
Old 05-31-2013, 02:59 PM   #8
Doe_Rae_mi's Avatar
Where are the grounds
Old 05-31-2013, 02:59 PM   #9
Sorry mis read it.
Old 05-31-2013, 03:04 PM   #10
Tyoung68's Avatar
Well they are wires that just bolt to the body idk where exactly you can follow the one from your battery also did you clean the terminals before you put them in? New battery's have a film on the terminals some times
Old 05-31-2013, 04:01 PM   #11
02mineralgreygt's Avatar
funny thing is the same thing happen to my gf about a month ago now...she drives a grand prix. I checked it all and it still wouldn't do anything, no lights came on no door chimes nothing, wouldn't even jump off. when i pulled the battery out and put it back in everything started working as its suppose to and haven't had the problem since...still to this day don't know what it was. All i know is it better not happen again
02mineralgreygt is offline   Reply With Quote
Old 05-31-2013, 04:22 PM   #12
Doe_Rae_mi's Avatar
Yea I cleaned my terminals I've done everything
Old 05-31-2013, 06:12 PM   #13
Brandon280's Avatar
I did buy a battery about three years ago that acted like that. For about a week it worked fine then it appeared dead. They tested it and it appeared fine but the voltage level may have been fine, but it had no arse(Amps to start t engine that is). Exchanged the battery and all was fine.
Old 05-31-2013, 06:22 PM   #14
Kevo91's Avatar
Region: Utah
Dang sounds like your having a hell of a time. I know this sounds dumb but did you check all your under hood fuses? Man when i had my 04 VW i wasted so much money replacing stuff...still no power at all, ended up being a damn little fuse
Kevo91 is offline   Reply With Quote
Old 05-31-2013, 11:05 PM   #15
Doe_Rae_mi's Avatar
Lol thanks for the help guys I'm still tryna figure this out
Old 06-01-2013, 07:36 AM   #16
Doe_Rae_mi's Avatar
Well guys I cranked it up this morning and it ran it and 3 seconds later it died
Old 06-01-2013, 07:38 AM   #17
Tyoung68's Avatar
Whens the last time you changed your fuel filter ?
Old 06-01-2013, 09:01 AM   #18
Doe_Rae_mi's Avatar
I doubt it's that because whenever I do get power it cranks and runs
Old 06-01-2013, 09:18 AM   #19
Tyoung68's Avatar
Yeah but you say only for a little? So the fuel could seep through when the cars off but when you need more it cant get any
Old 06-01-2013, 09:20 AM   #20
1996mustang's Avatar
Any fuse blown by any chance?
Old 06-01-2013, 09:27 AM   #21
Doe_Rae_mi's Avatar
Well yea that would make sense but it did it that time because I forgot to tighten my terminal and now I'm back to square 1 xD
---------- Post added at 11:26 AM ---------- Previous post was at 11:26 AM ----------
Idk how to check for that
---------- Post added at 11:27 AM ---------- Previous post was at 11:26 AM ----------
It's like whenever it does crank it runs perfect no problems at all.
Old 06-01-2013, 10:22 AM   #22
Tyoung68's Avatar
Old 06-27-2013, 12:32 PM   #23
Doe_Rae_mi's Avatar
Figured out what the problem was. Had a loose nut lol
06:17 AM
