Grinding noise. Stops when braking? - Mustang Evolution
Old 06-01-2013, 02:19 PM   #1
Coltonhess's Avatar
I've just recently been hearing this noise from the left front wheel area while driving. Is like a grinding sound like you were dragging a pipe against the ground. I only hear the noise sometimes and when I do the noise stops when I brake and while driving straight if you tip the wheel to the left it stops and comes back when tipped right. Any ideas?
Coltonhess is offline   Reply With Quote
Old 06-01-2013, 02:50 PM   #2
fastmustangs1's Avatar
Could be a pad rubbing on the rotor or perhaps maybe a wheel bearing going bad.
Can u post a vid of the noise?
fastmustangs1 is offline   Reply With Quote
Old 06-01-2013, 02:57 PM   #3
FortyBrandon's Avatar
Your throw out bearing. That's what mine was
FortyBrandon is offline   Reply With Quote
Old 06-01-2013, 03:16 PM   #4
Old 06-02-2013, 05:50 PM   #5
Coltonhess's Avatar
You had the same problem?
01:44 PM
