98 gt missfire - Mustang Evolution
Old 06-02-2013, 06:34 AM   #1
98slowGT's Avatar
98 gt missfire
I recently started to notice a slight missfire when I get on it in 2nd and 3rd gear. Anyone know some common causes or how I can go about fixing this? Thanks!
98slowGT is offline   Reply With Quote
Old 06-02-2013, 06:42 AM   #2
Count Dragula's Avatar
Spark plug or coil pack. Any codes?
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-02-2013, 09:45 AM   #3
98slowGT's Avatar
I recently did a tune up so idk if my spark plugs would be the issue and and check engine light isnt on so I doubt I throwing any codes
Old 06-02-2013, 10:26 AM   #4
Kevo91's Avatar
Region: Utah
Does it vibrate in the pedal and overall the car feels laggy when you punch it?
Kevo91 is offline   Reply With Quote
Old 06-02-2013, 10:31 AM   #5
Could be one of the coil packs but those commonly don't have issues... did you gap the plugs right when you installed them? New wires? What brand of plugs and type did you use? Have you done your fuel filter recently? When did you do your O2 sensors and have you tried to pull any codes? No CEL does not mean there isn't a code or an issue.
Old 06-02-2013, 07:57 PM   #6
98slowGT's Avatar
Its not really a vibrate just you can feel a slight lag for a half a second but it will do it in bursts at a time. And I know I gapped my plugs right and everything. I did my tune up in August so it really wasn't that recent. You really think the fuel filter could cause it? I probably should replace that anyway. My car never missfired until I beat the piss out of it at the ocean city car show in MD lol.
Old 06-02-2013, 08:19 PM   #7
Skulls98GT's Avatar
Had the same problem... 98's are notorious for having a cracked crossover on the intake where the thermostat sits. This will allow coolant to leak down by the heads and into the spark plug ports. Then causing misfire. After I replaced my intake I never had a problem.
Skulls98GT is offline   Reply With Quote
Old 06-02-2013, 08:41 PM   #8
Kevo91's Avatar
Region: Utah
My 98 is having the same problem as yours then. I thought maybe the clutch was slipping but my rpms dont shoot up. Ive been told it could be a fuel pump going bad or dirty injectors, its only when i floor it in 2nd and 3rd
Old 06-02-2013, 08:47 PM   #9
Kevo91's Avatar
Region: Utah
I just replaced all 8 plugs a week ago and properly gapped them all at 0.54 and im still having issues. Its worth a look anyway though
Old 06-03-2013, 09:25 AM   #10
98slowGT's Avatar
Thanks skulls. And yeah sounds like we have the same exact problem. Ive been meaning to change my pump and filters, just been real busy. Thanks for the advice guys
Old 06-03-2013, 05:22 PM   #11
Skulls98GT's Avatar
Your welcome. Not saying that's what your problem is... It's one thing I would look into though. Check out other things too, because a new updated intake with the aluminum crossover is around 300 bucks. I got mine from Latemodelrestoration.com. I have average mechanical skills and installed it myself. Went slow and took a crap load of pictures. There are lots if step by step instructions on-line to help you out too.
04:35 AM
