About to install new clutch - Mustang Evolution
Old 06-02-2013, 09:45 PM   #1
So I'm about to install my new exedy Mach 400 stage 2 clutch on my 02 gt. I have a spec stage 2 now but the thing was junk. Throw out bearing is shot. Clutch is slipping etc. crap. Anyways. I'm using a buddy's lift and I'm doing it all myself. First time really tackling a project like this. Just wanted to ask you guys beforehand if there's anything I need to know before hand. Any tips or problems I may encounter. Basically just any help before I get in over my head. Anything helps! Thanks.
bluegrassfever6 is offline   Reply With Quote
Old 06-02-2013, 11:00 PM   #2
PB blaster is your friend. Make sure you have several extensions of varying length and a few universal joints for the top starter bolt.
Get your flywheel resurfaced or buy new one...Make sure you clan with brake cleaner before and after install.
You can drain tranny first unless you want s mess our you have a tranny plug.
When you get to the top two tranny bolts, I'd unbolt the cross member and let the tranny drop it'll make those bolts a little easier to get at.
Take your time, label stuff as you remove our take pictures to help in remembering where things go. I used envelopes and just put bolts in and labeled them appropriately.
You'll definitely want at least one extra set of hands when dropping and reinstalling the tranny...two people makes it easier, the tranny is heavy and even with a tranny jack will be difficult to steady on your own.
Get your hands on a shop manual if you can, it provides step by step along with torque settings for all bolts.
That's all I can think of right now.
I just did this myself about 2 months ago. If it's your first time plan on at least a whole day...maybe 2 if you hit any snags.
**Edit**Oh and FRPP TOB is recommended. I used a Timken as it was highly recommended over at SVT Performance at the time I bought it (over 2 years ago). I think Timken stopped making them or went to Chinese factories and quality has suffered...so stick with the FRPP.
Old 06-02-2013, 11:36 PM   #3
Slow4V's Avatar
Starter might be a pain, resurface your flywheel
Old 06-03-2013, 12:33 AM   #4
Send a message via AIM to tedness
I second this that most aftermarket TOBs are crap. Stick to a quality FRPP unit. I put a Ram clutch, steel flywheel, and FRPP TOB in my car 35k miles ago and have had zero problems.
tedness is offline   Reply With Quote
Old 06-03-2013, 01:17 AM   #5
Venomouz831's Avatar
All of this is great info. An impact will help you greatly
)02 Gt, Founder of WE2G
Old 06-03-2013, 02:09 AM   #6
Also, get a clutch alignment tool, pretty much a must have. 10 spline for a 3650 trans. Also make sure you have a slide hammer to get the pilot bearing out. Its pretty straightforward, first time doing it on a lift will probably take you the better part of a day. Me and a buddy working can do one in about 3 hours...
Oh, getting your H pipe off if you have not done that before. The passenger's side collector has a nut that requires a cut down deepwell or a 1/2" drive socket. Regular socket is too shallow to bite and a regular deepwell is too deep to get in. Fun stuff.
03:14 PM
