Fuel pump failing? - Mustang Evolution
Old 06-03-2013, 09:01 AM   #1
2000 Mustang Gt's Avatar
Fuel pump failing?
I have a 2000 Mustang Gt and it is constantly stuttering when I drive. I changed the fuel filter yesterday and it ran great for a couple of miles then it started doing it again. What else could it be other than the fuel pump?
2000 Mustang Gt is offline   Reply With Quote
Old 06-03-2013, 09:11 AM   #2
Also it has 1/8 of a tank of gas and its 2+ months old. I had to replace the intake manifold and valve cover seals so I didn't drive it for a while. I thought it could be bad gas too?
Old 06-03-2013, 08:27 PM   #3
1996mustang's Avatar
It sounds as bad gas if it ran fine when u changed the gas filter. However it could be a pump. Try to rule it out by wasting all the bad gas change a fuel filter again woth new gas and check to see what happens then
Old 07-12-2013, 03:08 PM   #4
It turned out to be bad coil on plugs. I replaced them and now the car runs good as new!
---------- Post added at 04:08 PM ---------- Previous post was at 04:07 PM ----------
It turned out to be bad coil on plugs. Replaced all 8 and now the car runs as good as new!
Old 07-12-2013, 04:31 PM   #5
Well atleast that's a good thing u found the problem. Nice to learn something every day
03:22 AM
