Mgw vs pro 5.0 - Mustang Evolution
Old 06-05-2013, 02:35 PM   #1
Slp_loudmouth's Avatar
Mgw vs pro 5.0
I have a pro 5.0 but I wanna get an mgw wondering the benefits of the mgw vs pro and pics if you have one please
Slp_loudmouth is offline   Reply With Quote
Old 06-05-2013, 02:50 PM   #2
Region: Arkansas
Just a friendly reminder: use the search function. Here's what I post every time this comes up (I actually have it saved in a note so I can just copy/paste):
There's a reason MGW is the most expensive. It is absolutely the best there is. I've driven Steeda Tri-Ax (I had it on my car and I HATED that rattly piece of crap), Pro 5.0, Hurst (also had that on my car, it was awesome, but still comes in distant second), and MGW (on my car now!. MGW is the ONLY company with a unique shift mechanism. Steeda, Hurst, Pro 5.0, and every other company just rehash the worn out old factory shifter handle mechanism and raise the fulcrum up a tiny bit to make the throw shorter. It's exactly the same as your factory shifter; same slop, same crappy centering springs, same old junk design; you just pay for the higher fulcrum and billet casting. MGW completely redesigned the mechanics of the shifter by modifying the fulcrum location to be higher as well as changing the handle attachment design and allowing it to be fully adjustable. Their mechanism is more durable and gives the smoothest shifting possible, all while completely eliminating the rattle inherent in the factory/basic aftermarket design. Seriously, MGW costs more because its the best. It's completely adjustable from almost stock to just inches of throw (I don't know exactly how long it is, but mine is cranked all the way down and the throw is miles shorter than any other shifter I've ever driven). The handle even pivots to any direction. Sure, it gets really notchy at the shorter throws, but there's zero doubt about whether you're in gear. It clicks into every gear. The best part is the centering springs; they are just amazing! When going from 2-3, I honestly just push the ball straight up with my palm and let the springs pull me into the middle track. It's IMPOSSIBLE to miss 2-3 unless you're god-awful at driving a stick.
Here are a few photos:
ID:	112287   Click image for larger version
BackPressure is offline   Reply With Quote
Old 06-05-2013, 06:40 PM   #3
Geiger's Avatar
This is first gear (no its not as close to the dash as everyone thinks it is)
No more reaching for 5th.
2008 GT/CS , 17k original miles, bagged with airlift v2, cammed, and some bolt ons.
Geiger is offline   Reply With Quote
Old 06-05-2013, 07:02 PM   #4
Geiger's Avatar
How do you adjust the throw?
Old 06-05-2013, 07:06 PM   #5
Region: Arkansas
It's adjustable where the handle attaches to the lower cradle. Higher mounting of the handle = more torque applied and a longer throw.
There's also a screw that can be turned to adjust the firmness. Mine is cranked all the way down and my handle is mounted as low as I could so the shifter takes some effort to move. I love it!
Old 06-05-2013, 07:11 PM   #6
Geiger's Avatar
I have mine down as far as it will go too... Where is the screw that adjust firmness?
Old 06-05-2013, 07:20 PM   #7
Region: Arkansas
Kinda hard to miss, lol.
Old 06-05-2013, 07:42 PM   #8
Ewokjax95's Avatar
MGW all the way!!
Ewokjax95 is offline   Reply With Quote
Old 06-05-2013, 07:58 PM   #9
Geiger's Avatar
Oh.... I read somewhere to never touch that lol
Old 06-05-2013, 07:59 PM   #10
Region: Arkansas
I turned mine until I couldn't make it any tighter (approximately 10 turns from backed all the way out - which is the number of turns for the adjustment screw) That's all I know. It didn't have any negative effects so I assumed that's the adjustment screw.
Old 06-05-2013, 08:15 PM   #11
If you have the TR 3650 just make sure to not use any of the adjustable shift stops, there are already some in the transmission, so if you use any then you can damage the tranny.
---------- Post added at 07:15 PM ---------- Previous post was at 07:13 PM ----------
This is from the day i installed it.
Old 06-05-2013, 09:16 PM   #12
Region: Arkansas
+1
Very important info.
Old 06-05-2013, 10:31 PM   #13
jjsg09's Avatar
Ok looking at this im gonna look into getting one also. Im not totally happy with my tri-ax.
Old 06-05-2013, 10:32 PM   #14
Region: Arkansas
You will LOVE the MGW. If you don't, I'll give you $500. (Not really, but you get the idea)
Old 06-06-2013, 04:25 AM   #15
Geiger's Avatar
My mgw replaced a tri-ax. Its a slight improvement. But the biggest thing is its not loud and rattling all the time like the tri ax. The tri-ax was still a huge improvement over the spoon in a bowl of mashed potatoes feel of the stock shifter.
Old 06-06-2013, 08:50 AM   #16
jjsg09's Avatar
Hahahaha I like the analogy you used.
Old 06-06-2013, 09:48 AM   #17
Geiger's Avatar
Lol .... The sad thing is thats about right.
Old 06-06-2013, 06:51 PM   #18
cliffyk's Avatar
MGW FTW:
Read more about Mustang short throw shifters here...
Old 06-06-2013, 06:56 PM   #19
MidnightBlueGT's Avatar
I need a short throw, next mod will be gears, tuner, shifter.
Old 06-06-2013, 06:59 PM   #20
Slow4V's Avatar
Pro 5.0 is horrible
Mgw is the best
Old 06-06-2013, 07:09 PM   #21
99mustang99's Avatar
I absolutely love my MGW! I would go to those steedas or 5.0s one of the smoothest short throws i felt or had.. Recommended mod for any straight drive 99-04 mustang
99mustang99 is offline   Reply With Quote
Old 06-06-2013, 11:26 PM   #22
2002VertGT's Avatar
I didn't even read a single post in this thread. There are many threads about this. Mgw is far superior and the only shifter that uses its own design and not a remanufactured billet version of the stock with a shorter throw. Mgw is just plain awesome.
First gear
Reverse
Shifts amazing. Never miss a gear except 5th when I'm exhausted and too tired to push it all the way...
4.10 Gear/RPM thread
Old 07-20-2013, 02:50 PM   #23
GHO5T5NIPER's Avatar
Love your shift ball by the way. I was going to buy one but I called and they said 7-10 days how long did u have to wait for it if at all?
GHO5T5NIPER is offline   Reply With Quote
09:52 PM
