PI motor swap - Mustang Evolution
Old 06-06-2013, 03:26 PM   #1
96smoke's Avatar
PI motor swap
Ok so I'm currently looking for a full PI motor to swap in my 96 gt. I've been told itll fit just fine, but I'm wondering if any extra parts will need to be bought?
96smoke is offline   Reply With Quote
Old 06-06-2013, 03:29 PM   #2
Count Dragula's Avatar
I'm pretty sure just the computer system. It's basically the same motor with upgraded heads and intake
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-06-2013, 08:21 PM   #3
1996mustang's Avatar
no computer is needed at all really, its a straight foward swap from non pi to pi, of course you will need a pi intake pi heads, the coolant crossover that runs under the manifold, pretty much a heater hose i think anyways, all new manifold gaskets, antifreeze since taking the manifold off leaks out some coolant from where the nipple to the heater hose is, other than that i cant really think of anything else needed. valve covers as well i forgot lol
---------- Post added at 10:19 PM ---------- Previous post was at 10:16 PM ----------
only time to change the computer is when its bad, or goin from auto to manual or vice a versa, all you really are doin is upgrading heads and intake as dsg mentioned as well as bumping compression up to 10.5ish to 1, i wanna say 10.54:1 to be exact but im not sure on it to a decimal. this said limited to amount of boost later on unless you change the compression with either shorter rods, domed pistons or a cometic gasket like 3mm head gasket to lower compression. once again i may get corrected which is ok by me i learn more and you get better info imo.
---------- Post added at 10:21 PM ---------- Previous post was at 10:19 PM ----------
ignore all of it, i saw you said full pi motor swap, its a pretty straight foward swap on motors, no need to change ecu for it since like dsg said its an upgrade, so drop it in plug and play pretty much. my advice, 03 to 04 gt, due to the injector upgrade from the orange/yellow 19# injectors to the 21#injector (pink or lavander) which came stock on those years, ford changed over due to some reason im sure cliffy could expand on it, i think its cause of a better duty cycle and the 19# were getting pegged out.
Old 06-07-2013, 08:13 AM   #4
96smoke's Avatar
Lol yea I was gonna say I'm doing the whole motor but that's still good info to know! And yea thanks ill def look for 03-04 now. Plug n play is what I wanted to hear lol
Old 06-07-2013, 03:48 PM   #5
I've got a 99 Windsor PI motor in my 98. Done by the previous owner but it is literally a drop in. Old motor out, new motor in, swap over the coil pack setup and any accessories from the old motor to the new one. I personally like the coil packs better than the COP anyway and would recommend keeping them vs getting a conversion kit for that.
Old 06-08-2013, 09:46 AM   #6
96smoke's Avatar
Yea that's all I'm gonna do. It's really refreshing to know its a simple drop in
12:01 AM
