Comp Cams - Mustang Evolution
Old 06-06-2013, 09:17 PM   #1
BigB227's Avatar
Comp Cams
I know a lot of people run the stage II comp cams xtreme energy XE270AH but has anyone ran these or heard of these?? Which ones are better for performance?? Which set of cams have a better sounding idle? I saw these on Stage 3 motorsports
http://www.stage3motorsports.com/199...Shaft-Kit.html
And these are the 270s on AM
http://www.americanmuscle.com/mustan...s-xe270ah.html
BigB227 is offline   Reply With Quote
Old 06-06-2013, 09:33 PM   #2
BigB227's Avatar
What about these? Would these fit with stock PI heads??
http://www.compperformancegroupstore...de=MODFCAM2VXE
Old 06-07-2013, 10:47 AM   #3
BigB227's Avatar
Bump
Old 06-07-2013, 11:46 AM   #4
Mzilla's Avatar
Originally Posted by BigB227 View Post
Bump
What year is your car
Mzilla is offline   Reply With Quote
Old 06-07-2013, 11:49 AM   #5
BigB227's Avatar
2003 Mustang GT
Old 06-07-2013, 12:18 PM   #6
Mzilla's Avatar
The Xe270ah are a great set of cams for a PI car. The XE274h are designed for the non PI cars. The tri power cams will not make as much power or sound as aggressive.
Old 06-07-2013, 02:58 PM   #7
BigB227's Avatar
Aw oh ok thank you for clearing that up for me
Old 06-09-2013, 06:55 AM   #8
67mustang97's Avatar
Region: Vermont
Be careful I used those same cams in my stock engine and had valve clearance problems. I called Comp Cams and they said it's about a 50% chance of it having clearance issues. But now I have them in Trick Flow heads bolted to 5.1 stroker they do sound mean. With my stock engine I picked up 50 rwhp with these cams and a boost a pump.
Old 06-09-2013, 07:10 AM   #9
Slow4V's Avatar
That's hard to believe .. Any dyno sheets ?
Old 06-09-2013, 07:30 AM   #10
Count Dragula's Avatar
That only means he had 270.. That's believable
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-09-2013, 08:58 PM   #11
BigB227's Avatar
That's the only thing I'm weary of! I want that idle sound that the 270s give but I don't want to spend all the money to buy them and they don't fit and then I have to hell out more money for bigger heads
Old 06-10-2013, 11:21 AM   #12
Region: Vermont
I have my old dyno sheet 404 rwhp. Why is that hard to believe? Or you don't believe me when I said those cams destroyed my stock engine?
Old 06-10-2013, 12:25 PM   #13
BigB227's Avatar
They destroyed your stock engine???
Old 06-10-2013, 12:53 PM   #14
Region: Vermont
Yeah unfortunately I had clearance problems bent valves and dented pistons. I installed them in my new engine and they sound great with no problems. I needed to buy cam gears to go with the cams because my year the stock gears are pressed on not bolted like the Comp Cams. The gears alone are $289.99 from AM.
Old 06-10-2013, 02:15 PM   #15
BigB227's Avatar
Well now I'm reconsidering this because I don't want to pay $1000+ for the cams,gears as springs and they ruin my engine. I also don't have the money to dump into bigger heads as well as cams
Old 06-10-2013, 02:34 PM   #16
H.Doofenshmirtz's Avatar
Region: Australia
OP, i am still in your boat with regards to camming my '04 GT. I cant afford it now, so for the time being i read and read and read some more lol. I found this article a few weeks back and found the results interesting. I have been wanting the comp stage II's (the XE270AH) but those would almost certainly require some additional supporting hardware (springs, retainers, etc). Ok fine, but i see this article and has got me rethinking the direction i want to take.
https://www.dssracing.com/v/vspfiles...cam-motion.pdf
Big fan of the lopey idle characteristics of those 270's, but even the 262's will give some of that w/o (according to this article) low-midrange loss of tq AND no real need to replace the supporting hardware too.
Now i claim no actual or first-hand knowledge of this, so take this info with a grain of salt, but i thought to pass this along and hopefully help with your plans.
hth
No work and no pony makes Doof a dull boy...
H.Doofenshmirtz is offline   Reply With Quote
Old 06-10-2013, 04:06 PM   #17
BigB227's Avatar
hth
Great article!! Thank you very much!! Yeah the 262's sound like the best if both worlds at this point
Old 06-10-2013, 07:48 PM   #18
Region: Vermont
Good luck with the cams I hope what happened to me doesn't happen to you. The 262's are good sounding cams. It sucks the gears are so damn expensive.
Old 06-10-2013, 09:22 PM   #19
BigB227's Avatar
Yeah I know what you mean lol an yeah thanks everyone for the help
Old 06-12-2013, 03:35 PM   #20
Region: Vermont
Well Slow4V I'm waiting.... Don't be mad because a little 2V is faster than your 4V.
Old 06-13-2013, 06:27 PM   #21
Slow4V's Avatar
Lol that's cute, all that work for just 400rwhp lmfao,
I almost have all the parts for my eaton swap,
Just need heat exchanger , and tree.
Ill be around 440ish
And for about half the price you sent.
Don't be mad bro
Old 06-13-2013, 07:25 PM   #22
Region: Vermont
How do you know what I've spent? I'll post my new dyno slip once my engine is broke in 440 is a little weak.
Old 06-13-2013, 09:02 PM   #23
BigB227's Avatar
Here we go *popcorn*
Old 06-14-2013, 02:11 AM   #24
Slow4V's Avatar
At least over a grand ,
I've only spent 350 for parts so far, haha tree and exchanger on order for 80 bucks.
Maybe you should invest your money into appearance mods lmfao you need it.
---------- Post added at 03:11 AM ---------- Previous post was at 03:10 AM ----------
Your right but for a very safe 8psi it's a pretty good bang for the buck, with my setup being bone stock.
Old 06-14-2013, 03:00 AM   #25
1996v6stang's Avatar
We must all remember dyno sheets arent good for much. How bout time slips? Lmfao
1996v6stang is offline   Reply With Quote
Old 06-14-2013, 03:19 AM   #26
Slow4V's Avatar
No suspension or tires for a while for me ):
Soon I will, it's just the suspension parts and race stars I want are pricey ! Smh
Old 06-14-2013, 03:39 AM   #27
Money is always the issue. Haha sexy *** stang though man.
Old 06-14-2013, 03:48 AM   #28
Slow4V's Avatar
Lol yeah .. I'm just necio and have large fines..
Smh
Oh well young and dumb gotta learn some how..
Thanks , yours is badass too !
Old 06-14-2013, 04:13 AM   #29
Slow4v you can't start crap with someone about there car "only" having 404 rwhp before you even have your supercharger installed or all the parts lol, it does sound a bit low but ease up I'm sure he does have a ton of money into it, but good luck on your build.
BlackStang00 is offline   Reply With Quote
Old 06-14-2013, 05:02 AM   #30
Slow4V's Avatar
You as well man ,
Well I'm young so and dumb I blow my money on dumb **** Lol.
Old 06-14-2013, 05:27 AM   #31
Slow4V's Avatar
Dude I can honestly care less about my car even having over 400rwhp , id rather spend the money on other things. This guy started trying to be a hardass saying oh your just mad my car is faster than yours, like really? Okay cool guy, he must not get enough attention at home obviously, because he has to try to be noticed on here.
Old 06-14-2013, 06:13 AM   #32
Region: Vermont
Your the one that started **** calling me out because I said I gained 50rwhp by adding cams and a boost a pump. really you don't think that is possible??? You talk like a *** I've seen your other posts putting 2V's down saying they are junk. 4V's are awesome except for the head cooling issue they have but come on... Here is some of my best runs lets see yours. Yeah I do have more money in my car who cares what I've spent, not to many good used parts up here in Vermont.
Old 06-14-2013, 06:24 AM   #33
Slow4V's Avatar
Lol glad I made your morning big man haha
Old 06-14-2013, 06:34 AM   #34
Slow4V's Avatar
I honestly don't have any videos ,
Best 13.3 @107
X pipe / short throw
2.3 60ft
And IMO I think they suck , I'm not pointing out anyone's cars. I've just had the worst luck with my previous 2 GTs
And personally would never go back to a 2v
And yeah I don't see how the hell someone would get 50rwhp from just cams NA I didn't see that you had a V3 which makes alot of sense
Old 06-14-2013, 07:46 AM   #35
2300turboford's Avatar
Best 13.3 @107
2.3 60ft
2.3 60ft ? You need traction my friend lol
10:16 PM
