? Edelbrock Victor Jr on 4.6 - Mustang Evolution
Old 06-07-2013, 10:24 AM   #1
jjsg09's Avatar
I have a friend that wants to know if you can use this setup on his bolt on/naturally aspirated 03 GT. I told him I wouldn't do it it looks like its made for cammed or blown Mustangs. He said he wants it more for looks than for power. He just thought it looked cool anyone to know if it would work well with this car. So I told him I would ask the guys from ME. What do you think?
Here it is I n AM if anyone wants to see.
http://www.americanmuscle.com/edelbr...ld-9904gt.html
Old 06-07-2013, 10:46 AM   #2
Mzilla's Avatar
I personally have this intake on my 04. I also have 18-20lbs of boost being shoved thru a 6061 elbow. I have fully built teksid block and stage 2 cams. An NA car with no mods will choke and loose a lot of torque. I would recommend an Accufab upper plenum and throttle body if he wants bling and functionality.
Mzilla is offline   Reply With Quote
Old 06-07-2013, 12:47 PM   #3
If he puts it on he's going to hate it. On a bolt on GT that intake will lose a ton of low end and not pick up much if anything up top. The PI intake is a proven winner and there really isn't a better offering until you get to bigger cubes or a blown application. If he wants it to look better he can upgrade the plenum and do some other stuff. He'll also need more than just the intake like the elbow and fuel rails. Not smart, not smart at all on his part honestly.
Old 06-07-2013, 03:19 PM   #4
slow281
sixpac's Avatar
Region: Nebraska
Trick flow or bullitt are the only two that have gains on NA but be ready to fork out the big bucks
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-07-2013, 03:33 PM   #5
They are completely not worth it. I see ppl spending $1k to get a bullitt setup on their car and laugh. $1k for 5wtq and an added 30-40lbs to the nose of your car. Have fun. The TFS intake isn't worth it either. IMO, stay PI until you hit the 16+lb boost mark and not because of flow issues, I just would not trust a plastic intake after that. I've seen ppl run like 24lbs no problem and make upwards of 700whp though all through the stock plastic intake though. I am personally going tork tech with a ported M112 so no intake issues for me...
Old 06-07-2013, 03:48 PM   #6
slow281
sixpac's Avatar
Region: Nebraska
+1 the do change your powerband tho.. It's may only be 5hp peak but.. There's other factors..
2001 GT - True Blue
Old 06-07-2013, 06:10 PM   #7
Mzilla's Avatar
I lost 10ftlbs of torque upto 3900rpm. My HP took off at 5200rpm and ran out of wind at 7400rpm
Old 06-07-2013, 06:25 PM   #8
I'm not saying it isn't a better intake, just not $1k and 40lbs better. If I had an all out NA car I'd be a 5.4L 2V with TFS heads, seriously port matched adapter plates and then I would run the Edelbroke or a 4.6L stroker 4V with ported 03-05 Revised heads and an 99/01 Cobra or 03/04 Mach intake.
Actually if I was doing a NA Mustang build I'd probably go with an older fox I could register as a classic or 94/95 Cobra I could put collector registration/insurance on to completely avoid emissions altogether and drop a worked 408 into it.
Old 06-07-2013, 06:43 PM   #9
slow281
sixpac's Avatar
Region: Nebraska
That's what I love about Nebraska.. Not to get off topic.. But I've got my 93 cobra.. LT headers gt40 intake.. Street legal.. Right now working on finding someone to rebuild the motor..
2001 GT - True Blue
Old 06-07-2013, 06:50 PM   #10
Eh, I we can have anything we want on the cars here in NJ as long as it passes the sniffer. However if its OBDII they just plug into the computer to make sure there are no emissions codes and call it good which is one reason I now have a modular.
Lol and the wife wants me to try to put in for orders to California... I think being military I can stay NJ registered/inspected though...
Old 06-07-2013, 07:00 PM   #11
slow281
sixpac's Avatar
Region: Nebraska
Mine wouldn't pass haha
2001 GT - True Blue
Old 06-08-2013, 07:29 AM   #12
Mzilla's Avatar
Emissions whats that?? I have all my emissions removed EGR and cats. When I go to get mine done they asked do you have high flow cats um yes. Good thing they didn't bend down and look. Haha
Old 06-08-2013, 08:09 AM   #13
slow281
sixpac's Avatar
Region: Nebraska
Off topic but how do you like the egr delete?
2001 GT - True Blue
Old 06-08-2013, 08:35 AM   #14
Mzilla's Avatar
Honestly there is no difference i did it to clean up under the hood around the intake
Old 06-08-2013, 11:57 AM   #15
There really is 0 reason to delete the EGR unless you just want to get rid of all the junk under the hood. And nobody ever wants to pay for the tune to properly turn it off either lol.
Old 06-08-2013, 12:17 PM   #16
99mustang99's Avatar
I have it, does clean up under the hood nicely also pcv delete and cat delete too
99mustang99 is offline   Reply With Quote
Old 06-08-2013, 12:31 PM   #17
slow281
sixpac's Avatar
Region: Nebraska
Got a picture and never heard of the PVC delete??
---------- Post added at 01:31 PM ---------- Previous post was at 01:30 PM ----------
Pcv*
2001 GT - True Blue
Old 06-08-2013, 12:35 PM   #18
Heres my engine bay, pretty sure it was the tubes that went to the valve covers( where my oil breathers are )
Old 06-08-2013, 12:45 PM   #19
slow281
sixpac's Avatar
Region: Nebraska
Looks clean just heard its not good for it?
2001 GT - True Blue
Old 06-08-2013, 12:58 PM   #20
Depends if its done right honestly, mine runs perfectly fine at 40,000miles on a built engine
Old 06-08-2013, 01:09 PM   #21
01bullitt's Avatar
stock 2v with stage 1 mhs cam went 12.5 the setup works
01bullitt is offline   Reply With Quote
Old 06-08-2013, 01:15 PM   #22
Built 2v, full forged internals, pcv egr cat delete.. Stock intake manifold 78mm CAI, custom dyno tuned with ecu chip and lots more lol
---------- Post added at 03:15 PM ---------- Previous post was at 03:14 PM ----------
Your in NC too?
Old 06-08-2013, 01:22 PM   #23
01bullitt's Avatar
Your in NC too?
yea im in nc Jacksonville.. this is my buds car in az..my car is a bullitt. bullitt intake 65mm twin tb k&n cai o/r x slp lm1 gears tuner
Old 06-08-2013, 01:23 PM   #24
Ever heard of Oakboro? Lol
Old 06-08-2013, 01:33 PM   #25
01bullitt's Avatar
haha no
Old 06-08-2013, 01:38 PM   #26
haha no
Good ole oakboro cruise inn, small town haha.. Ive been near jackson a few times im more near charlotte
Old 06-09-2013, 06:00 PM   #27
To adress both of the isues that have come up in this thread,...I ran a Victor Jr on my 2v for a total of 12k miles in one year,..all w/ a carburetor and the PCV system converted over to breathers on the valve covers. The car managed 23+ MPG at 73 mph on the I state going to Mustang week,...and several of the other day trips I took so I can't imagine that the intake killed off too much torque.
Warning,...this is a carb'd picture,...so if it is gonna bother you,...avert your eyes.
2003 Zinc yellow Cobra (Rescued shelter dog)
C.A.I.; 2.8 upper pulley;Non-catted off road pipes w/ Mac flowchamber, Flowmaster cat back. EGR delete; Head cooling mod;
My 5.0 feature:http://www.mustang50magazine.com/fea...d/viewall.html
mike1157 is offline   Reply With Quote
Old 06-09-2013, 06:03 PM   #28
Clean very clean
01:11 PM
