Sct custom tune - Mustang Evolution
Old 06-07-2013, 01:49 PM   #1
Sct custom tune
Does anyone know where I could get a rpm limiter custom tune
Todd Fuson is offline   Reply With Quote
Old 06-07-2013, 01:57 PM   #2
03GT88's Avatar
Should I had a diablo and I could set rev limiters for neutral and in gear.
03GT88 is offline   Reply With Quote
Old 06-07-2013, 02:08 PM   #3
1lowGT's Avatar
I got the live wire and I can set rev limiters
Old 06-07-2013, 07:57 PM   #4
i have a sct x3 i thought came with the rev limiter,but it doesnt and ive called the company that makes it and the one i bought it from and they cannot help me with it.
Old 06-08-2013, 06:12 AM   #5
cliffyk's Avatar
If you have a custom tune provided as a file to be loaded onto your X3, or one that was loaded onto the device before you bought it, the User Adjustable options will not be available unless the creator of the tune file enabled them--most do not as they do not wish to be liable for a user messing things up and damaging the engine.
BAMA or any SCT shop can provide a tune with the rev-limiter increased (or decreased) from the stock 6050 RPM of most GTs. You should also be able to elect to load one of the pre-programmed "canned" tunes, and at that point answer Yes to the Adjust User Parameters prompt. This may not be the exact process as I have not used an X3 in years...
Old 06-08-2013, 05:32 PM   #6
Frankinstang's Avatar
Go to americanmuscle.com. They have bama tuners with rev limiter options and free custome tunes for life.
Frankinstang is offline   Reply With Quote
02:29 AM
