Procharger question - Mustang Evolution
Old 06-07-2013, 09:40 PM   #1
2002VertGT's Avatar
Ok, I have a procharger. I still need to get upgraded fuel pump/s and a better maf. Would it be a bad thing if I hooked it up on all the stock stuff and just ran a really really mild tune on it. I want it out of my closet but the only place I want it besides out if my closet is on my car.
4.10 Gear/RPM thread
Old 06-07-2013, 10:16 PM   #2
Count Dragula's Avatar
Originally Posted by 2002VertGT View Post
Ok, I have a prochamber. I still need to get upgraded fuel pump/s and a better maf. Would it be a bad thing if I hooked it up on all the stock stuff and just ran a really really mild tune on it. I want it out of my closet but the only place I want it besides out if my closet is on my car.
You won't have nearly enough fuel going to the motor. You need injectors, and a fuel pump at least.
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-07-2013, 10:39 PM   #3
2002VertGT's Avatar
I have 42lb injectors....idk if it just adds 50hp ATM.
Old 06-08-2013, 07:27 AM   #4
WheelStander's Avatar
You're 42 pound injectors are good that's what I'm running.
Get the BBK fuel pump from lethal performance its a direct bolt up.
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 06-08-2013, 08:23 AM   #5
2002VertGT's Avatar
What hp is it good to?
Old 06-08-2013, 08:35 AM   #6
I think it's around 500
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-08-2013, 09:00 AM   #7
If lethal sells it its good stuff and proven winner.
I'll get the link.
This is a direct bolt in replacement no wire splicing or anything:
http://www.lethalperformance.com/bbk...-assembly.html
I think my dual Cobra pumps are something like 355 lph.
Old 06-08-2013, 10:54 AM   #8
2002VertGT's Avatar
One reason in asking this is I don't have hundredsof dollars to buy everything needed to push the high numbers ATM. I just want to get it on...
Old 06-08-2013, 11:27 AM   #9
You will damage the engine without pump.
Old 06-08-2013, 12:21 PM   #10
MidnightBlueGT's Avatar
+1
---------- Post added at 02:21 PM ---------- Previous post was at 02:16 PM ----------
I say just say up and make sure you get all the supporting mods before rushing into install. Rebuilding a whole engine is a lot more expensive than waiting in that fuel pump
Old 06-08-2013, 08:21 PM   #11
Gera8712's Avatar
OP.. I know its kinda dumb question...You talking about prochamber or procharger by reading the posts I'm assuming you meant procharger but I just wanna make sure lol
Gera8712 is offline   Reply With Quote
Old 06-08-2013, 08:22 PM   #12
I didn't even see that! Lol
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-08-2013, 08:47 PM   #13
2002VertGT's Avatar
Hahah yes, must have auto corrected and I didn't catch it.
Old 06-08-2013, 08:53 PM   #14
Gera8712's Avatar
Lmao I knew what you meant, just wanted to give you a hard time lol
Old 06-08-2013, 09:03 PM   #15
slow281
sixpac's Avatar
Region: Nebraska
I need injectors and wanted to go bigger then just 21 lbs.. If I get it tuned is it okay to have like 32lb injectors on almost stock motor for now? (Sorry to get off subject
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-08-2013, 09:06 PM   #16
I have heard you can run as big as you want and that doesn't mean it will put more fuel in. So you could run 80+ and the amount of fuel going in the motor will be the same as 21 because the computer is reading that it doesn't need all that. I don't think you need a tune but I can be 100% wrong too....
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-08-2013, 09:19 PM   #17
slow281
sixpac's Avatar
Region: Nebraska
Cool thanks for the info.. I only have 10 because its pre 02
---------- Post added at 10:19 PM ---------- Previous post was at 10:19 PM ----------
19lbs*
2001 GT - True Blue
Old 06-08-2013, 09:25 PM   #18
19lbs*
I would doubt check that to make sure. I could be wrong
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-08-2013, 09:48 PM   #19
2002VertGT's Avatar
I was told not to put my 42lbs in till I put the sc on...
---------- Post added at 11:48 PM ---------- Previous post was at 11:44 PM ----------
I'll get the link.
Yo wheelstander is this the complete fuel pump? Cause I know like the cobra hats have to have the fuel pump in them, and this doesn't look like the pumps I'm used to seeing.
Old 06-08-2013, 09:48 PM   #20
I've always heard you can still run with a bigger injector and it won't hurt because the computer will only send so much. Like I said though I think we need a expert because I could be wrong lol
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-08-2013, 09:49 PM   #21
And yes that's the complete fuel pump.
2007 Mustang Gt
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
Old 06-09-2013, 05:42 AM   #22
DSG is correct about the injectors.
That pump is a direct replacement.
I can ask a guy who put one in just to make sure but even Lethal said it's direct plug and play. Did a lot of research on this before I stumbled into my dual pumps.
---------- Post added at 07:42 AM ---------- Previous post was at 07:39 AM ----------
Wait.... that link I sent is for 99 00.
You have 02. That's different.
Let me find the 02 pump.
Old 06-09-2013, 06:28 AM   #23
This is what you need:
Finally a direct replacement fuel pump for your 01-04 Mustang V6, GT or 2001 Cobra. No fabrication required! Replace or upgrade your factory in tank electric fuel pump with this direct fit, variable flow fuel pump kit. These BBK Performance fuel pumps can be used as a stock replacement or an upgrade when running a higher horsepower engine. The 300Lph fuel pump supports high horsepower but still allows for great driveability, making it equally at home in stock or highly modified applications.
BBK Performance 01-04 Mustang V6 & GT / 2001 Cobra 300 LPH Fuel Pump Assembly - BBK Performance - Fuel Pumps - Fuel Delivery - 99-04 Mustang GT
Old 06-09-2013, 09:26 AM   #24
2002VertGT's Avatar
Ok I just wanted to make sure it wasn't a hat that still needed a pump.
08:21 AM
