took the car to the dragstrip, no longer able to shift gears - clutch dead? - Mustang Evolution
Old 06-08-2013, 08:28 PM   #1
Took my 2000 GT 5-speed with just mild bolt-ons (251rwhp) with street tires to the drag strip today, and on my first pass launching from idle, the RPMs suddenly went high gears 1 through 4 but the car was hardly accelerating..
When I slowed down and tried to shift gears the car would no longer shift. I had to turn the car off, then I managed to shift the gear into first and restart the car...
The car lurched forward in 1st gear upon restart, and the only way I could shift gears was without the clutch, but rev-matching the synchros and managing to shift into higher gears.
The clutch pedal feels fine, so I do not think it is a snapped cable. The car also smells like burnt clutch, and there was a bunch of smoke on my first and only run at the drag strip following my car.
Anyone know what it could be? Should I expect more damage than just a destroyed clutch? Flywheel? I didn't really feel any vibrations driving the car at 60mph back home in 5th. I have a new valeo clutch (king cobra kit) for the car.
2000 Atlantic Blue GT
paradigm is offline   Reply With Quote
Old 06-08-2013, 10:44 PM   #2
Krazy Horse's Avatar
Sounds like you ate the clutch disc on your pass. May have lost one of the springs inside the disc itself
Krazy Horse is offline   Reply With Quote
Old 06-09-2013, 12:31 AM   #3
Venomouz831's Avatar
Pop the little canister on the bottom by the clutch. If little shreds of like wood type are there than you might of ate the clucth and from what you stated that's what I believe it is
)02 Gt, Founder of WE2G
Old 06-09-2013, 08:27 AM   #4
Originally Posted by Venomouz831 View Post
Pop the little canister on the voting by the clutch. If little shreds of like wood type are there than you might of ate the clucth and from what you stated that's what I believe it is
Where is this little canister you speak of? I am not sure what the voting is?
Old 06-09-2013, 09:09 AM   #5
The inspection cover. Two bolts hold it on and should be on the driver side of the transmission under the car.
Old 06-09-2013, 09:27 AM   #6
Yep
Old 06-10-2013, 07:51 AM   #7
MustangGT02's Avatar
I had a POS valeo in my car when I did my first autocross in my stang. It did the same thing, I all the sudden had no clutch, turns out the clutch was shattered into a bunch of the wood type shreds like stated above. I now have a RAM clutch and I can tell the valeo was just junk.
MustangGT02 is offline   Reply With Quote
08:17 AM
