Drag radials - Mustang Evolution
Old 06-08-2013, 10:17 PM   #1
Chasafire888's Avatar
Drag radials
Does anyone have any recommendations for streetable drag radial tires that will last a while if i run them on the streets?
Chasafire888 is offline   Reply With Quote
Old 06-08-2013, 10:27 PM   #2
Krazy Horse's Avatar
Nitto 555r will most likely be your best bet for good dual purpose tire
Krazy Horse is offline   Reply With Quote
Old 06-08-2013, 10:36 PM   #3
ive been running the mickey thompson's for a yr and they are awesome, I never spin my tires, they hook like glue, and wear has been minimul
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-09-2013, 12:34 AM   #4
Venomouz831's Avatar
Hoosiers is also a good one
)02 Gt, Founder of WE2G
Old 06-09-2013, 07:15 AM   #5
Slow4V's Avatar
Nitto blow
MT drag radials are perfect
Old 06-09-2013, 11:54 AM   #6
While Nittos are not the best drag radial as far as hooking up, they are great for someone who wants a stickier tire that won't wear out in five thousand miles. I hook up great on my Nittos, not as good as I did on the BFGs on my Cobra but much better than a regular street radial. Just be aware that Nittos run a little narrow compared to other brands. My 315 wide tires out back are exactly flush with the 10.5" rim. Here is how mine fit.
265/40/17 Nitto 555s on a 17x9" rim up front:
315/35/17 555Rs on a 17x10.5" Rim out back:
IMO, for a combination of grip and tread life you will have a hard time finding a better tire than the Nitto.
Old 06-09-2013, 04:05 PM   #7
Thanks guys that helped a lot
Old 06-09-2013, 06:26 PM   #8
Crowned1's Avatar
Originally Posted by Slow4V View Post
Nitto blow
not to go off topic but can you PM me slow4v?? I have question about something.
Crowned1 is offline   Reply With Quote
11:07 AM
