Octane booster??? - Mustang Evolution
Old 06-09-2013, 06:13 PM   #1
Corndog's Avatar
Octane booster???
What is the best octane booster or fuel to run in a 2v with a procharger?
Corndog is offline   Reply With Quote
Old 06-09-2013, 06:52 PM   #2
93. Add torco if you need more octane in a pinch. Buy racegas otherwise.
Bottom line is run what you are tuned for.
Old 06-09-2013, 07:22 PM   #3
Slow4V's Avatar
Mine runs good with 93 and a octane booster but I wouldn't recommend doing it all the time. Maybe once in a while ..
Old 06-09-2013, 07:39 PM   #4
Corndog's Avatar
Ok I only run 93 I just wasent sure I I should add anything
Old 06-09-2013, 07:40 PM   #5
93 and tune for 93, make sure you get from a gas station you trust if you require 93 for bad things not to happen to your motor. If you go to the track then you can also have a tune for that loaded on a handheld and fire it up after you load up the tank with a few gallons of that.
02:09 PM
