idk What went Wrong - Mustang Evolution
Old 06-10-2013, 06:58 PM   #1
Anth0nyxGT00's Avatar
Post idk What went Wrong
im having this rough idle problem i bought a 00 GT in Feb havent had any problems out of it besides a minor leak coming from the oil filter just recently i hit a minor pot hole ran it on the freeway got off nd at the light i had a rough idle i cleaned the MAF with CRC also cleaned the throttle body with CRC installed a spectre CAI nd used stp fuel injector cleaner nd still a rough idle the only other thing i can think is to do a tune up is there anything else i can check i also checked all the hoses nd clamps i see no leaks no abnormal noises idk wut to do or check also im having this really funky smell coming from my exhaust
Anth0nyxGT00 is offline   Reply With Quote
Old 06-10-2013, 07:01 PM   #2
1slosix's Avatar
clean the IAC...you can use your CRC
carving corners like a boss
Old 06-10-2013, 07:43 PM   #3
will that get rid of the smell
Old 06-10-2013, 07:46 PM   #4
1slosix's Avatar
is the funky smell like un burned gas?
Old 06-10-2013, 07:56 PM   #5
yea or as if yu cleaned out yur fuel system i used to work at a place called ez lube nd when we did a fuel system clean it would make the same funky smell
Old 06-11-2013, 12:51 AM   #6
Mathew r Wright's Avatar
In burned fuel? I don't about you but I would look for an exhaust leak. Plus take a look at the o2 sensors, and you can't go over everything without missing something trust me I drive a high mileage car...
---------- Post added at 01:51 AM ---------- Previous post was at 01:51 AM ----------
I ment un burned fuel sorry...
Mathew r Wright is offline   Reply With Quote
Old 06-11-2013, 09:48 AM   #7
i was thinking exhaust leak nd i def will check o2 sensors
Old 06-11-2013, 09:59 AM   #8
H.Doofenshmirtz's Avatar
Region: Australia
Might be worth a shot to check COPs and plugs while ur at it
No work and no pony makes Doof a dull boy...
H.Doofenshmirtz is offline   Reply With Quote
Old 06-11-2013, 12:53 PM   #9
+1...
Old 06-11-2013, 04:31 PM   #10
cleaned the IAC still the rough idle i think its either a vacuum leak or exhaust
Old 06-11-2013, 08:36 PM   #11
DWC_SmOziLLa's Avatar
Buy ME Gear!!!
:cool
Official MustangEvolution.com Gear
Old 06-11-2013, 09:34 PM   #12
02GtRespect's Avatar
You said smell of fuel was this before or after spectre cai? Correct me if Im wrong but maybe just maybe that smell is from it running a little rich due to the air/ fuel ratio being changed from cai. Some people said they got cel and other multiple symptoms from their cai. Just a thought for the smell.
02GtRespect is offline   Reply With Quote
Old 06-12-2013, 09:26 AM   #13
the smell was there right after the rough idle everything transpired right after i hit the pot hole the idle nd also the smell
Old 06-12-2013, 10:06 AM   #14
its more of a carbon burn off smell if any 1ne knows wut that smells like
Old 06-12-2013, 04:33 PM   #15
so i just came from pepboy auto nd they hooked up the OBDII nd it gave the Code P305 the misfire code smh there are so many things listed here ruined my day they also charge 89.99 to run a diagnostic test i started my car nd left idk wut to do really
Old 06-12-2013, 07:44 PM   #16
White03GT's Avatar
Do you have cats still? I bet that's part of or is your problem if you do.
White03GT is offline   Reply With Quote
Old 06-12-2013, 08:43 PM   #17
Geiger's Avatar
Isnt p305 a cylinder 5 misfire? If so , change that plug injector and cop and see if it goes away. Or move cops around ect to see if the misfire moves to the other cylinder.
2008 GT/CS , 17k original miles, bagged with airlift v2, cammed, and some bolt ons.
Geiger is offline   Reply With Quote
Old 06-12-2013, 08:44 PM   #18
yea i do nd where i live alot of shops wont take em off
---------- Post added at 07:44 PM ---------- Previous post was at 07:43 PM ----------
yea it is i had researched it when i got home
Old 06-12-2013, 08:52 PM   #19
Geiger's Avatar
Should be an ease fix... Start with a spark plug for money purposes
Old 06-12-2013, 10:00 PM   #20
White03GT's Avatar
Check the coil by swapping it with another coil too. Hope it's not a valve though or the cats, the weird smell statement gave me the idea for the cats
Old 06-14-2013, 08:36 PM   #21
checked the spark plug it was fine so was the coil i did a little more research nd found that the smell nd the idle is coming from the cats the symptoms are rough idle at stopping nd the sulfer smell
"One of the effects of a catalytic converter that isn't operating correctly is an engine running with a rough idle. When you are at a stop light or sign, you will be able to feel an unusual shaky sensation."
"Symptoms
Another symptom of a catalytic converter being damaged is the smell of sulfur when the engine is running. Sulfur odors are similar to the smell of rotten eggs"
Read more: Symptoms of Catalytic Converter Damage | eHow Symptoms of Catalytic Converter Damage | eHow
Old 06-14-2013, 08:54 PM   #22
White03GT's Avatar
"Symptoms
+1 same thing happened to me and it was a bad cat, I just did away with them and picked up a few more ponies.
Old 06-15-2013, 04:03 AM   #23
Geiger's Avatar
Ive heard of cars with bad cats doing some funky things.... But could that be if its just throwing a code for 1 cylinder misfire?
Old 06-16-2013, 04:21 AM   #24
yea ill be getting rid of mine soon as i find a shop willing to wut state are yu in
Old 06-16-2013, 04:28 AM   #25
that is the question idk i changed the 5th plug i need to do all i will in a couple weeks when money frees up but 1ne i changed the plug it ran smoother jus the idle nd smell but when i take the cats off then ill know 4sure
Old 06-16-2013, 10:44 AM   #26
White03GT's Avatar
Texas
Old 06-16-2013, 07:55 PM   #27
http://www.walkerexhaust.com/support...onverter-fails
Jus read this it explains why the code came up most likely it surprising me how much can go wrong jus from the cats sheesh
Old 07-08-2013, 12:37 PM   #28
I finally figured out wut the problem was jus a bad coil on the 5th cylinder swapped it out now the car runs like a dream can't wait to replace all of em
Old 07-08-2013, 12:38 PM   #29
Venomouz831's Avatar
Good
)02 Gt, Founder of WE2G
Old 07-08-2013, 07:08 PM   #30
2000 Mustang Gt's Avatar
I have a 2000 gt and had the exact same problem! It was very frustrating! I tried all kinds of things and nothing worked until I bought all new motorcraft ignition coils. Now it runs like new!
2000 Mustang Gt is offline   Reply With Quote
Old 07-08-2013, 07:34 PM   #31
Man same here only good thing about it was i changed and cleaned parts of the car that needed to be changed and cleaned lol
Old 07-09-2013, 01:04 AM   #32
I did the same here. My engine was dirty and I did a lot of cleaning since I was in there anyways!
10:07 PM
