Labor for gear install? - Mustang Evolution
Old 06-13-2013, 08:34 PM   #1
Kevo91's Avatar
Region: Utah
Hey guys, I searched the threads but none directly answered my question. So I want to install 3.73 gears on my 98 gt but I don't really have the proper tools or equipment at my house to do it. Has anyone gotten it done at a shop? what should I be expecting for labor cost? Luckily mine has 3.27 already so its not totally worthless lol
Kevo91 is offline   Reply With Quote
Old 06-13-2013, 08:37 PM   #2
slow281
sixpac's Avatar
Region: Nebraska
400+
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-13-2013, 08:38 PM   #3
Kevo91's Avatar
Region: Utah
dang that blows
Old 06-13-2013, 08:50 PM   #4
2300turboford's Avatar
Very time consuming and alot of. Trial and error
Old 06-13-2013, 09:23 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
dang that blows
Yepp it's not cheap and you have to factor in fluid and seals.. That's 150$ there
2001 GT - True Blue
Old 06-13-2013, 09:26 PM   #6
Kevo91's Avatar
Region: Utah
Thanks for the input guys. I figured it would be pricey but someday ill be better equipped too do it myself. I can live with the 3.27 for now until I save up, can still break the tires loose and smoke ricers super easy
Old 06-13-2013, 09:50 PM   #7
BigB227's Avatar
I payed $350 for just install, I supplied all the parts, fluid and seals
BigB227 is offline   Reply With Quote
Old 06-14-2013, 01:44 AM   #8
tc x 4's Avatar
Guys that have been working on cars for 30yrs can't do it. It takes a lot of skill to set one up right. Anything less than $500 is a good deal if it doesn't whine. As 2300 said, its a lot of trial an error, putting it together and taking it back apart. After a time or two, most guys say
f it and bolt the cover on.
Old 06-14-2013, 01:49 AM   #9
Venomouz831's Avatar
I am currently in the procces of doing mine with a friend, I am preety good mechanically and my friend is a mechanic. I'm almost done taking the diff down just need a few more bolts and bam. 350+ is what they will most likely quote you
)02 Gt, Founder of WE2G
Old 06-14-2013, 01:53 AM   #10
tc x 4's Avatar
Where's your jack stands brother.lol
Old 06-14-2013, 01:54 AM   #11
It does not take a lot of skill to rebuild a rear end nor is it difficult to do. This is a very basic necessity to being a mechanic and if you are one and can't do it that's just sad but yes you do need proper tools and some patience for trial and error to properly set it up. If you've done it once you can do it 100 times. 8.8s are also one of easiest ones to do besides a 9 inch labor is expensive though as well as parts simply because rear diff fluid is high. And a whine is usually caused by improper pinion bearing preload or from re using a crush sleeve which is an absolute "no no" even though I've seen it done
BlackStang00 is offline   Reply With Quote
Old 06-14-2013, 02:08 AM   #12
Their right behind the jacks lol.
Old 06-14-2013, 02:12 AM   #13
Slow4V's Avatar
150-200 should be right
Old 06-14-2013, 02:15 AM   #14
For labor? Not anywhere I have worked for , at 75 to 100 an hour at any given shop these days 300 to 400 is more likely for labor.
Old 06-14-2013, 02:20 AM   #15
MidnightBlueGT's Avatar
250 is the lowest ive seen for this install. If you can find for 150 go for it! But make sure they know what they're doing
Old 06-14-2013, 02:26 AM   #16
Slow4V's Avatar
I got mine done for 150 at a mustang dyno shop..he quoted me 150 labor again for the mach 1,
Well I'm in a mustang crew, and we sometimes chill with the tech. When we have Fundraisers or track nights, so that may be why..
I was going to do my gears by myself next time. It's easy it's just the back lash you have to get correct.
Old 06-14-2013, 02:27 AM   #17
Yeah that's a good buddy for sure but backlash an your bearing pre loads and correct contact pattern
Old 06-14-2013, 02:29 AM   #18
tc x 4's Avatar
You can have the correct back lash, and the wear pattern be way off.
Old 06-14-2013, 02:30 AM   #19
I've never had experience doing gears or anything like that so i figure im spending a good bit for the gears and kit might as well have it done properly than me f'ing something up
Old 06-14-2013, 04:55 AM   #20
Kevo91's Avatar
Region: Utah
Thanks everyone. So from the sounds of it the price will vary depending on the skill of the guy working on it, labor is typically 95/hr here
Old 06-14-2013, 05:28 AM   #21
Slow4V's Avatar
Just make sure they are ford gears and you will be alright,
Old 06-14-2013, 06:41 AM   #22
Kevo91's Avatar
Region: Utah
I plan on getting ford racing gears unless anyone has a better suggestion
Old 06-14-2013, 06:47 AM   #23
Slow4V's Avatar
Best gears ,
Old 06-14-2013, 07:16 AM   #24
tc x 4's Avatar
Labor should be no more than 4hr.
Old 06-14-2013, 07:40 AM   #25
Especially on the 8.8 if it was a 9 inch it would be a piece of cake
07:13 PM
