Camber bolt help? - Mustang Evolution
Old 06-14-2013, 05:56 PM   #1
slow281
sixpac's Avatar
Region: Nebraska
Camber bolt help?
I ordered the camber bolts but I'm a noob when it comes to suspension.. So I have no clue how to use them or ware to put them.. Should I just take it to a pro? And I did search Round but more just found what they do.. Not how to install them.. Bassicly I cut my springs so my tires are like this
/|||/----\|||\ so they sit heavy on the inside..
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 06-15-2013, 01:10 PM   #2
1996mustang's Avatar
the camber bolts replace the bottom of the 2 bolts on the strut. when you get the camber bolts it will have instructions on how to mount them, taking the tire off would make it easier to access the bottom strut bolt so that reinstall would be easy. after that you need to go get it aligned. if there is a pep boys around you they can do the camber/wedge and alignment. they will looked grooved and somewhat out of round, which allows alignment on the camber + or - roughly 1.75 degrees , i.e positive or neg camber adjustment.
this should give you an idea on how to install one. granted its like the 07 mustang i did today, same concept on our body style as well. also on the video he installed his camber bolt on the top one, while i did it on the bottom bolt, either bolt allows you to adjust camber, however imo the bottom bolt is the correct one to remove and replace with the camber bolt...... just saying since i do this all the time at my job lol.
Old 06-15-2013, 02:00 PM   #3
slow281
sixpac's Avatar
Region: Nebraska
So do I need more positive?
2001 GT - True Blue
Old 06-15-2013, 05:43 PM   #4
Yes right now you are negative camber id atleast say -2° in. So you would have to adjust the camber positive wise to get back to spec which i think is -0.8° is center for our car. Pretty much negative is inclined in like you have it mentioned so with the camber kit u will adjust towards positive.
/||/ \||\ you now
\||\ /||/ tooo postive
|||| |||| were u want it.
You can eye it somewhat on the camber or have a magnetic leveler to put on a wheel so you can somewhat put it in line. Its up to u on how u wanna do it.
Old 06-15-2013, 06:01 PM   #5
slow281
sixpac's Avatar
Region: Nebraska
/||/ \||\ you now
|||| |||| were u want it.
Good! So ode I get the bolts.. Should I just let a pro put them in and align at the same time?
2001 GT - True Blue
Old 06-15-2013, 06:31 PM   #6
1lowGT's Avatar
I'll help you when I get home and post some pictures for you.
Old 06-15-2013, 11:02 PM   #7
Would be recommended however you could install yourself and have them align it
Old 06-15-2013, 11:06 PM   #8
slow281
sixpac's Avatar
Region: Nebraska
Yeah I was just thinking they probably wouldn't charge me much to install them..
---------- Post added at 12:06 AM ---------- Previous post was at 12:03 AM ----------
Do I put the camber bolt in the bottom one or top one..
2001 GT - True Blue
Old 06-15-2013, 11:10 PM   #9
I do it on the bottom however you could up top really a preference to the installer and the one who has to align its convenience. But imo id do it on the bottom so u get more angle adjustment than up top. Its that imo its easier to install and u get more adjustment than up top.
Old 06-18-2013, 06:23 PM   #10
slow281
sixpac's Avatar
Region: Nebraska
What ones should I buy?
2001 GT - True Blue
Old 06-18-2013, 06:36 PM   #11
When u buy it it comes as a pair so one for each side
Old 06-18-2013, 06:38 PM   #12
These are from an 07 stang our years will be similar bolts to these
Old 06-18-2013, 07:13 PM   #13
slow281
sixpac's Avatar
Region: Nebraska
I know that ware do I get them?
2001 GT - True Blue
Old 06-18-2013, 07:32 PM   #14
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I bought the Eibach camber bolts from AM. I think they were around $24.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 06-18-2013, 07:38 PM   #15
Oh lol well pepboys can order them for u. Am as well so will lmr and many other sites. Am is free shipping so that's a plus
Old 06-18-2013, 11:01 PM   #16
I personally like to run 1-2 degrees of negative camber on my cars, but ford set the stock specs around .5 degrees of negative camber. Right now I'm at -1.5, and my tires are wearing perfectly even.
Old 06-18-2013, 11:12 PM   #17
slow281
sixpac's Avatar
Region: Nebraska
Idk what I'm at but the inside is wearing more then the outside..
2001 GT - True Blue
Old 06-18-2013, 11:17 PM   #18
slow281
sixpac's Avatar
Region: Nebraska
How do I tell how much I'm running?
2001 GT - True Blue
Old 06-19-2013, 08:15 AM   #19
There are some cheap ish camber gauges, but its probably best to get a professional alignment.
Old 06-19-2013, 01:04 PM   #20
If u lowered your car my guess would be about -2 degrees camber in. Just my guess assuming you did a 1.5" drop. You will know if u take it to get a free alignment check they will put your car on the plant and see what degree ur cambered in and how off your toe is
Old 06-19-2013, 03:57 PM   #21
slow281
sixpac's Avatar
Region: Nebraska
Cheapest bolts I can find are 28$ sucks for just two bolts
2001 GT - True Blue
Old 06-19-2013, 09:04 PM   #22
Sadly those cheap bolts save u hundreds of dollars allowing u to align ur car correctly
---------- Post added at 11:04 PM ---------- Previous post was at 11:01 PM ----------
Tires ain't cheap lol
Old 06-26-2013, 05:32 AM   #23
Geiger's Avatar
I have a brand new set of eibach camber bolts ill sell for 20 shipped
2008 GT/CS , 17k original miles, bagged with airlift v2, cammed, and some bolt ons.
Geiger is offline   Reply With Quote
Old 06-26-2013, 08:39 AM   #24
slow281
sixpac's Avatar
Region: Nebraska
Ugh I just bought some.. Dam..
2001 GT - True Blue
Old 06-26-2013, 09:09 AM   #25
Geiger's Avatar
Thats how it works lol
01:46 PM
